Throttle Rail Return Springs - BMW Luxury Touring Community
post #1 of 12 Old Oct 10th, 2006, 8:56 am Thread Starter
murray's Avatar
Question Throttle Rail Return Springs
Has anyone disconnected any of the return springs in a effort to reduce the throttle resistance?
I have the updated 2005 cables installed although improved not totally happy.
Thanks for the feed back.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #2 of 12 Old Oct 10th, 2006, 12:03 pm
Check the routing of the new cables through the fairing. Too tight of a bend can make them stiffer than they should be. And don't assume that because you did it the same as the previous cables that it is right. after all, you replaced those because they were too stiff, right?
post #3 of 12 Old Oct 10th, 2006, 1:43 pm
True, But prior to attaching the cables I checked the cables for smooth operation. Yes the cables move freely and smooth. So I would say the cable bend is not a problem.
Back to the spring disconnect , Those springs sure do create alot of resistance. Anyone disconnect one of the springs?
Petem aka murray
PeteM is offline
post #4 of 12 Old Oct 10th, 2006, 1:52 pm
johnrehder's Avatar
Smile 3 springs
Pete,
I accidently unhooked the middle spring when I changed my cables out this weekend. There are three of them. I hooked it back up because I did not want to take a chance on not having enough pressure to properly close the throttle, however when I adjusted the cables too much one direction the throttle got really stiff in operation so I lossened the adjuster nut untill the throttle spung back on its own freely. Played with a bunch of different settings too. Try adjusting the cables first and see if it loosens the play.
Petem aka murray
looking around for a possible replacement
2001 K1200 LTC Mauve (Hi-Way Star) may she rest in peace!
CCR'2001 Hotsprings, AR., Sante Fe, NM., Gatlinberg, TN.
Breckinridge, CO., Grand Teton Nat. Prk, WY.
Chateau Elan, GA., Tan-a-Tar-A missed it!
johnrehder is offline
post #5 of 12 Old Oct 10th, 2006, 1:57 pm
CharlieVT's Avatar
Throttle springs
I have thought about doing this too, it was a very easy modification on old four carb Hondas. Not so easy on the LT and I gave up on it. There was a post some time ago by someone who had "relaxed" the return spring by repositioning the "keeper' on one end of the spring.
That post may be in the archives of the old board.
Edited to add:
Here's a old post on the subject. David Shealey's... I should have guessed. So, ping David and he'll probably be able to give you more details.
http://www.bmwlt.net/ubbthreads/show...=&view=&sb=&o=
CharlieVT is offline
post #6 of 12 Old Oct 10th, 2006, 6:44 pm
mneblett's Avatar
Definitive answer: I have done this. The throttle rail would not *reliably* return that last RCH back to the idle stop.
It *might* not have been a problem when the engine is running (vibration to help the throttle close), but I wasn't willing to risk it, and hooked the spring back up. I strongly recommend not taking the chance of not being able to maintain accurate throttle control, particularly at low speed/small throttle openings.
FWIW, the carbs were low mileage at the time (<4K?), so there was no issue as to whether they were hanging due to deposits, gummy residue, etc.
Mark Neblett
Fairfax, VA
mneblett is offline
post #7 of 12 Old Oct 10th, 2006, 8:40 pm Thread Starter
murray's Avatar
Smile
Originally Posted by johnrehder
Pete,
Thanks John also varied the freeplay without change.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #8 of 12 Old Oct 10th, 2006, 8:48 pm Thread Starter
murray's Avatar
Edited to add:
Charle , Mark thanks for the effort.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #9 of 12 Old Oct 11th, 2006, 7:39 am
Pete and Charlie,
I had same prob w/ new 06 LT...all was ok, thats when they showed me the 3 STRONG springs on the rail.
Here is a work-a-round if everything mechanical is OK;
He told me to try the "Throttle Rocker" www.throttlerocker.com
Cost $10 for the right. Loved it so much I went and bought the left for $8 and two more for my HD. My bro bought them also after trying mine.
The leverage and hand platform comfort are unbelievable!
CHEAP NON PERMINENT INVESTMENT
be safe
2013 BMW Damask Red K1600GTL
2014 BMW K1600GTL-E EXCLUSIVE
2001 Honda C-250 Helix
Smokin'
SmokinJoe is offline
post #10 of 12 Old Oct 11th, 2006, 8:00 am
mneblett's Avatar
Originally Posted by SmokinJoe
Pete and Charlie,
be safe
I'll second that! Mine has been on four LTs -- the bikes may come and go, but the Throttle Rocker stays!
Mark Neblett
Fairfax, VA
mneblett is offline
post #11 of 12 Old Oct 11th, 2006, 2:39 pm
AlaskaFish's Avatar
Wink
And I'll third that! The Throttle Rocker can be a life saver on a long trip if you do lose your Cruise, as I found out coming home from Breck a few years ago. Boy is it nice to just stretch those fingers.
John & Marilyn Fisher
'00 K1200LTC "Katie"
'95 Triumph "Tigger"
Hillsboro, Oregon
AlaskaFish is offline
post #12 of 12 Old Oct 11th, 2006, 5:21 pm
CharlieVT's Avatar
Throttle Rocker Thread!
Yeah, Throttle rockers. I've got three. One bike, the old CB550 Honda just doesn't need one.
If you have the old, non-velcro, throttle rocker here's the modification I developed to keep it from slipping:
Rock on....
(clever, huh?)
Throttle cable replacement notes johnrehder K1200LT 26 Aug 8th, 2013 7:54 am
Stiff Throttle 02lt K1200LT 19 Sep 17th, 2011 1:37 pm
Question - LT Throttle Cable Service Bulletin? DRM K1200LT 20 Aug 20th, 2008 7:26 pm
New Zip, sticky throttle, not all cables parishollow K1200LT 1 Mar 29th, 2006 9:16 am
Feeling a little chill tonight? Try hot springs pjessen Chit Chat 0 Feb 5th, 2006 10:42 pm
