Fuel leak - help - BMW Luxury Touring Community
post #1 of 4 Old Oct 9th, 2006, 7:26 am Thread Starter
jdanek's Avatar
Question Fuel leak - help
My '02 sprung a fuel leak this weekend from the pressure hose connected to the fuel pump. I tried to tighten the clamp (using a plier) but gas still spraying out the end of the hose.
The hose itself feels a bit worn so I figure it would be best to install new hoses, clamps, and quick disconnects on both the pressure and return lines.
Should I purchase these parts from my dealer? It looks like the hoses can be removed and installed without taking off the gas tank (although there isn't much working space below the fuel pump). Do I need some special crimping tool for the hose clamps?
Any other options or recommendations? i.e. Can I purchase the hoses, clamps, and quick disconnects from someone other than BMW and crimp everything together myself?
'02 K1200LT Silver
St. Augustine, FL
jdanek is offline
post #2 of 4 Old Oct 9th, 2006, 7:34 am
kellenbenz's Avatar
You can replace the crimp type clamps with worm type from your local hardware store. To get you by, you can just use a barb spline type connector instead of the quick disconnects. Is it the disconnect that is leaking, usually it is? Take the disconnect to the hardware store for them to get you the proper barb spline connector. I think it was 5/16 but not positive on that.
HTH,
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #3 of 4 Old Oct 9th, 2006, 8:54 am
2000klticon's Avatar
5/16 hose barb
It takes a 5/16 hose barbed coupling to replace the quick-connect. I had one go bad this summer, it broke in two where the retaining clip holds them together.
Phil
2000klticon is offline
post #4 of 4 Old Oct 9th, 2006, 6:35 pm
zippy_gg's Avatar
Lightbulb
See this related thread with source for rings and steel Quick Disconnects
http://www.bmwlt.com/forums/showthread.php?t=15031
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
K1200 Fuel Leak g_laskie K1200LT 39 Jun 11th, 2012 9:41 pm
1999 fuel leak piusg K1200LT 3 Jul 26th, 2006 1:29 pm
Fuel Leak after 2004 Inspection TomHaycraft K1200LT 0 May 13th, 2006 9:46 pm
Pretty Heavy Fuel Leak tyroneteeth K1200LT 2 Oct 13th, 2005 6:00 pm
