greasy front rim - BMW Luxury Touring Community
post #1 of 6 Old Oct 5th, 2006, 12:21 pm Thread Starter
omurphy's Avatar
greasy front rim
my 2000 lt had a fine coating of grease or oil on both sides of the front rim with some on the spokes. 74k miles on it. it's not brake fluid; i've checked. i drove home and gave it a good bath. it's been a while since it has had one. i've been working third shift so i hadn't noticed the grease until this morning although i noticed what i thought was dirt or brake dust a few days ago when i checked the tire pressure, but it probably wasn't as bad then as this morning. i've noticed for quite sometime a little grease coming from between the seal and axle on the right hand side, and there was some there this morning. i had the 12 k service done in aug. the dealer has never mentioned a problem with the wheel bearings. i checked the archives and it does mention possibly changing the bearings at around 72k, but it doesn't mention anything regarding a greasy rim. when i washed the bike this morning i didn't feel any roughness in the bearings. so perhaps i need seals. one other thing since returning from the dealer 72k service, i had a locale shop put on a new front tire. any thoughts or comments will be appreciated. i will probably not respond today as it's well past my bed time and i've got to go to work tonight. thank you, omurphy
omurphy is offline
post #2 of 6 Old Oct 5th, 2006, 2:31 pm
Any time you pull the front axel you are supposed to apply a light film of grease to it (keeps it from seizing to the bearings). The shop may have gotten carried away and used a bit too much. Check it again after a few miles and see what shows up.
post #3 of 6 Old Oct 5th, 2006, 3:16 pm
grifscoots's Avatar
The bearings are sealed with just a cap over them. They are a bear to remove and you better have the axle in place after putting in the spacer BEFORE you place the 2cnd bearing.
-=grif=-
Grok
grifscoots is offline
post #4 of 6 Old Oct 5th, 2006, 9:02 pm Thread Starter
omurphy's Avatar
thanks, my intention is to visually inspect after some miles and check the temperature (lay hand near then on). omurphy
omurphy is offline
post #5 of 6 Old Oct 5th, 2006, 9:09 pm
wilbar00c's Avatar
Reach up around the front strut tubes with a paper towel to insure you do not have a weeping strut seal that lets a little oil run down the back side of the strut and maybe onto the axle area. Mine was dripping off the right brake caliper about 4K miles ago. It has since stopped on it's own.
BMWMOA 89402
wilbar00c is offline
post #6 of 6 Old Oct 6th, 2006, 3:02 pm Thread Starter
omurphy's Avatar
thanks wilbar. give dino a pat on the head for me. muchos gracias senior. omurphy
omurphy is offline
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 11:48 pm
Front Axle Is Stuck! microdoc K1200LT 15 Jul 4th, 2006 4:45 pm
Low front tire miles, and rear brake noise tobiwan K1200LT 1 Jul 3rd, 2006 11:42 pm
Front End problems!! km5bh K1200LT 36 Apr 9th, 2006 10:03 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
