Sticky Stud Stumps Me - BMW Luxury Touring Community
post #1 of 6 Old Oct 4th, 2006, 10:00 pm Thread Starter
acs5166's Avatar
I'm "ripping" off my final drive to fix it. Everything has come off so far just as described in the shop manual with a couple exceptions. The two screws holding the brake rotor on seems to be only hand tight and the floating stud lock nut on the wheel side of the drive took very little force even though the book warned about high torque needed.
As my luck runs though, the last bolt - the fixed stud on the outside - seems to be welded in place. It uses a 15mm hex. I've tried a soft hammer on the hex wrench. A heat gun and even a blow torch for a short moment. Then a steel hammer on the hex wrench. I'm a bit nervous because it looks almost like an aluminum nut instead of steel.
Any and all advice for breaking this loose is appreciated.
Thanks - Jack
2000 K1200LT (still hurting)
acs5166 is offline
post #2 of 6 Old Oct 4th, 2006, 11:15 pm
Try a piece of pipe slipped over the hex wrench (which should be a 12MM). It is a high torque item just like the lock nut should have been(160Nm). Hopefully no one has used locktite on this as it will be tough to get it free.
post #3 of 6 Old Oct 4th, 2006, 11:58 pm Thread Starter
acs5166's Avatar
Sorry, you're right it's 12mm. I'll have to find a pipe and give it a try. Thanks!
-- Jack
acs5166 is offline
post #4 of 6 Old Oct 5th, 2006, 12:27 am Thread Starter
acs5166's Avatar
John - That did the trick! I took my hydraulic lift handle and used that. The only problem was that I forgot I didn't have a rear wheel on and almost tipped the bike over backwards! Then I stood up and held up the back of the bike while stepping on the handle and it finally gave way. Wow was it in tight.
Thanks for your help!
Cheers - Jack
acs5166 is offline
post #5 of 6 Old Oct 5th, 2006, 8:57 am
You do have the cut - away 30 MM socket to torque (160 Nm)the jam nut WHILE holding the lightly torqued (7 Nm)pin? Glad the bike didn't tumble on you. Good point to remember - place a block under the rear drive before popping the pin.
post #6 of 6 Old Oct 5th, 2006, 4:13 pm
When I took mine off it wasn't 'too' tough but still had to use a pipe.. and the bike did hop around on the center stand... a block of wood under the rotor would keep the bike steady and not damage the rotor.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
Broken Exhaust Manifold Stud...Groan! JATownsend K1200LT 11 Oct 2nd, 2006 9:28 pm
Shifter => Transmission Linkage Stud Broke Reid K1200LT 15 Jul 4th, 2006 5:33 pm
Exhaust manifold stud walnut11 K1200LT 2 May 25th, 2006 2:40 am
exhaust stud broke parishollow K1200LT 9 May 10th, 2006 7:36 pm
snap lock stud davek1 GPS 3 Apr 15th, 2006 11:42 am
