Throttle cable replacment help - BMW Luxury Touring Community
post #1 of 5 Old Oct 3rd, 2006, 9:09 pm Thread Starter
I am replacing my throttles cables on my 02Lt I ordered these cables for the 05 conversion
327 376 944 90 - Throttle
327 376 944 91 - Acc. Cable
327 276 919 90 - Repair Kit
the cables fit great but the kit came with only one piece, picture enclosed. Should the kit contain more then one piece how does not it hold the cable secure because my outer piece on my 02 does not not fit with kit/conversion thanks Stan
saustin02 is offline
post #2 of 5 Old Oct 4th, 2006, 6:23 am
There should be 2 plastic pieces; the backing plate that screws to the inner hand grip housing. This also supports the cable on the inside. The outer piece covers the cables (forms a sandwich with the inner plate) and screws to the inner plate.
The original inner plate can be cut off from around the grip with a pair of dykes; the replacement is semi-circular and does not need to fit around the grip (just screw it in place). Role the grip back to gain access to the screws with your screwdriver.
Chuck J
02 K1200LT (Black Beauty)
New friends make it all worthwhile!!! Smile, its catching.
ksailor is offline
post #3 of 5 Old Oct 4th, 2006, 6:54 am
grifscoots's Avatar
The lower handlebar cover needs to be replaced, too. Or, you can hack the old one, but not as nice looking.
-=grif=-
Grok
grifscoots is offline
post #4 of 5 Old Oct 4th, 2006, 7:58 am
My dealer replaced mine. They replaced the lower handlebar cover. From the outside it looks the same but it is expensive so many have just modified the old one. They claim it works so you might want to save some money and do it that way.
ATFLT is offline
post #5 of 5 Old Oct 4th, 2006, 10:42 am Thread Starter
missing part
I called bobs bmw after talking with parts dept the kit should have come with more parts. I only recived one piece. Now waiting for replacment kit .
thanks for your help
Question - LT Throttle Cable Service Bulletin? DRM K1200LT 20 Aug 20th, 2008 8:26 pm
Help with throttle cable upgrade sbrooten K1200LT 10 Jun 20th, 2007 10:08 pm
Is it OK to lube throttle cable? damenke K1200LT 4 Apr 18th, 2006 1:01 pm
Throttle Cable adjustment McAllister K1200LT 3 Jan 5th, 2006 11:16 am
2001 Throttle Cable Recall ? PHILBERT40 K1200LT 3 Nov 17th, 2005 10:58 am
