Does anyone have a spare EHCS Module? - BMW Luxury Touring Community
 5Likes
  • 2 Post By 14wntr
  • 1 Post By alexs
  • 1 Post By 14wntr
  • 1 Post By K1200_Pav
post #1 of 20 Old Apr 13th, 2016, 3:33 pm Thread Starter
14wntr's Avatar
The bike I am working on has all three issues going on with the CS. Leaking seals, bad motor and no voltage to the plug. I pulled the relay and tested it. Good. Wiring and ground is patent. I am getting the 4hz lightning bolt flash when the button is pressed. I have verified there are no LED's in the tail light and no fuses are blown.
All that to say I am looking for a used module now because I feel like I have run out of options.
2000 K1200LT-C "Tsukune"
2013 Honda NC700X "Moka"
Kirk Johnson
President of
14wntr is offline
post #2 of 20 Old Apr 13th, 2016, 5:11 pm
Re: Does anyone have a spare EHCS Module?
You also must have side stand up and be in neutral with no brake applied (or brake light on). Also there is a tilt sensor so you must be upright. I have yet to see a bad controller
post #3 of 20 Old Apr 13th, 2016, 5:33 pm Thread Starter
14wntr's Avatar
The bike is on the lift, on the center, no brakes or lights. I have checked with the center up as well so as to not mess with deploy sensor. I have unplugged the deploy sensor and tried that too. The side stand is up. Where is the tilt sensor so I can check that too? I feel like I am doing everything I can aside from running another switch to the relay and bypassing the module. There is power on the hot 12v side of the relay. There is just no signal to set it off. Is there something in the relay/fuse block under the tank that could be bad? Oh yeah, brand new fully charged battery as well.
Kirk Johnson
President of
14wntr is offline
post #4 of 20 Old Apr 13th, 2016, 7:53 pm
JNW003's Avatar
For what it's worth, mondrage (see post #6 of the thread "Re: K1200LT EHCS Centerstand Issues") has a spare. Unfortunately, he lives in Nicaragua, so that probably wouldn't help Kirk much in Illinois...
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #5 of 20 Old Apr 14th, 2016, 8:22 am
I'll be traveling to Milwaukee in two weeks.
If you still need it by then let me know.
I haven't received yet, but I should have it this week, after it goes through customs.
BMW K1200LT 2007
BMW K1200R: "Drophammer" 2006
BMW R1200GS 2008
BMW K1200S 2007
Suzuki DR-Z400E 2000
Sachs MadAss FY125-20
mondrage is offline
post #6 of 20 Old Apr 15th, 2016, 2:26 pm
YIt will do nothing if the center stand is deployed except flash a light. You need to check it with the front wheel in a chock and the cs up.
post #7 of 20 Old Apr 15th, 2016, 2:43 pm Thread Starter
14wntr's Avatar
I did do that as well. Thankfully I got it running again. It turned out to be a combo platter of a bad motor, ground and corrosion in the sealed connector. Now I need a drink! Thank you for all the help!
Patric and gorm5 like this.
Kirk Johnson
President of
14wntr is offline
post #8 of 20 Old Apr 17th, 2016, 9:47 am
And here I thought I had a buyer for the EHCS module...
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #9 of 20 Old Apr 18th, 2016, 7:23 am
Yes, I have one available. See my ad in the Classified section. Cecil (318) 541-3257
k5lo is offline
post #10 of 20 Old Apr 26th, 2016, 8:32 am
I'm in Milwaukee. If anybody needs the EHCS module please let me know.
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #11 of 20 Old Dec 19th, 2019, 9:20 pm
alexs's Avatar
Posting my experience so is documented:
I had the same issue as described in the thread start, flashing EHCS yellow light @4Hz and the lightning symbol on the board computer display. This after a full clutch job.
I disconnected the EHCS motor plug under the bike, used a spare battery (12V) and appropriate copper leads to power the EHCS motor until the center stand started to move down, but not all the way. After that the error was gone, the EHCS works again.
Mark65 likes this.
"05 LT
alexs is offline
post #12 of 20 Old Feb 20th, 2020, 11:21 am
K1200_Pav's Avatar
Having problems myself now with the EHCS, I moved the bike to do some work in the garage and the center stand worked. Come to park it back up in the garage and nothing, all I get is the center stand warning light flashing . I can hear just hear a relay clicking on and off when I press the stand button. The battery is just over 12 volts at the moment, and connections look good on the battery and the terminal blocks by the battery. Checked the brake lights and they are working alright and have normal bulbs in them. Any ideas where to start with looking for the fault?
K1200_Pav is offline
post #13 of 20 Old Feb 20th, 2020, 11:32 am Thread Starter
14wntr's Avatar
I would pull the electric motor and see if it works or not. Check the 12v down there while you are at it.
K1200_Pav likes this.
Kirk Johnson
President of
14wntr is offline
post #14 of 20 Old Feb 20th, 2020, 11:51 am
Check this out, in case you need to find a motor. But also check if the piston has fluid:
Originally Posted by francis83 View Post
Hi Franck
Files interesting for you : http://www.bmwlt.com/files/albums/us...%20Circuit.pdf and http://www.bmwlt.com/files/albums/us...%20Sourced.pdf
Visit also this site for visual explanations https://plus.google.com/photos/11657...329?banner=pwa.
You will know that the electric engine is a HS-50N for Honda scooter and you can find it here http://www.emsglobaldirect.com/product.php?productid=27 or other sites.
Have a nice Sunday
Bikely
BMW K1200LT 2007
BMW R1200GS 2008
BMW K1200S 2007
mondrage is offline
post #15 of 20 Old Feb 20th, 2020, 11:57 am
K1200_Pav's Avatar
The motor does need the oil changing as must be well knackered by now, I have new seals somewhere as it was on the list of things to do, miss placed them at the moment as moved house and still in a packing box. Some of the links unfortunately do not work.
post #16 of 20 Old Feb 20th, 2020, 6:30 pm
You can find the motors on ebay they are starter motors for a Honda CH80 Elite scooter. Some times the motors develop corrosion on the brush ground screw. You can open it up but hold the geared shaft with a vise or pliers when you pull off the magnetic housing that way the brushes stay on the commutator.
post #17 of 20 Old May 19th, 2020, 2:22 pm
K1200_Pav's Avatar
Apologises in the long delay in getting back to you. Finally got around to looking at the bike today. The motor stand motor is dead, opened it up and the brushes had completely worn out all that was left was the brush springs. Now the hunt begins to find a new motor at a reasonable price.
post #18 of 20 Old May 19th, 2020, 2:41 pm Thread Starter
14wntr's Avatar
https://amzn.to/36pCTHb
Kirk Johnson
President of
14wntr is offline
post #19 of 20 Old May 19th, 2020, 3:11 pm
K1200_Pav's Avatar
Originally Posted by 14wntr View Post
Thank you, unfortunately import duty, postage and carrier handling fee to the UK make importing from the States an expensive thing, though if can't source one here easily its an option and just have to pay the fees.
post #20 of 20 Old May 21st, 2020, 4:42 pm
K1200_Pav's Avatar
Managed to find a new one in Spain for £27 including postage just got to wait for the postie.
jzeiler likes this.
K1200LT EHCS Centerstand Issues mondrage K1200LT 12 Dec 19th, 2019 9:18 pm
EHCS flushing and elec. motor maintenance TSQUARED North West 1 Mar 26th, 2013 6:34 am
Didn't make it back home - anybody got a spare ABS module? N5PN Curve Cowboy Reunion 15 Sep 11th, 2011 7:49 pm
Bleeding/Flushing fluid in EHCS on 05+ LT's TSQUARED North West 2 Apr 27th, 2011 2:15 am
Most likely cause for EHCS not working? atps1234 K1200LT 4 Mar 11th, 2007 1:29 pm
