Wilbers on an 06 - BMW Luxury Touring Community
post #1 of 5 Old Oct 2nd, 2006, 11:01 am Thread Starter
graydude's Avatar
Wilbers on an 06
I'm tying to mount a pair of Wilbers from my 02 onto my 06. The front went in without a problem. I can't get the rear to line up. Any of you with an 05/06 had any problems getting the shock to line up? This is how far I'm off. Any suggestions would be great.
Todd/Graydude
2005 K1200 LT "Graphite Graydude Metallic"
Todd "Graydude" Ask me why I'm the best Realtor you've ever met!
IBA#22266
graydude is offline
post #2 of 5 Old Oct 2nd, 2006, 11:55 am
motorhead's Avatar
The top eye is NOT symetrical, rotate body 180 degrees & it should slip right in.
Then twist preload collar into position that works best & your set
Scott
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #3 of 5 Old Oct 2nd, 2006, 12:00 pm Thread Starter
graydude's Avatar
Thanks. Tried that. The picture shows the flat side facing the engine. The only thing I can thnk of is to grind where the shock is hitting the motor. That's really my last resort as I can't believe that's the only fix.
IBA#22266
graydude is offline
post #4 of 5 Old Oct 2nd, 2006, 12:59 pm
mneblett's Avatar
It probably is. I remember that when the Ohlins first became available for the LT, there were a few reports of need to grind, so this is not unheard of. Seemed to be just a random manufacturing tolerance stack-up issue.
Mark Neblett
Fairfax, VA
mneblett is offline
post #5 of 5 Old Oct 2nd, 2006, 1:16 pm Thread Starter
graydude's Avatar
Mission Accomplished
Thanks for the help and PM's guys. I heard from enough of you that a BFH might be needed to coax the bolt into the hole. Much as I hate using brute force on anything, I got the bolt through and tightened. Now I'm gonna sweat the next 30K miles before I have to take the shocks off again for rebuild . But like many of you have said, just ride the bike and the petty stuff goes away
IBA#22266
graydude is offline
Suspension.....(again!!!....sigh) PhillWard Australia, New Zealand, and AsiaPac 26 Nov 13th, 2006 11:38 pm
Wilbers Ordering Mishap rattso K1200LT 12 May 16th, 2006 2:27 pm
Wilbers Shocks Questions rattso K1200LT 10 Apr 11th, 2006 10:08 am
A Wilbers Shock Question rattso K1200LT 2 Mar 28th, 2006 3:01 pm
Have Wilbers, Will Install Matt Mid West 5 Mar 18th, 2006 12:42 am
