Radio problem - BMW Luxury Touring Community
post #1 of 5 Old Oct 2nd, 2006, 6:44 am Thread Starter
tazz56's Avatar
Unhappy Radio problem
I've tried searching w/o success. The buttons on top of the tank light up if I push the,"on" button, but nothing else happens. No sound, not even anything showing on the screen.
This started when I tried to set the stations for what I like to hear. When I would try my pre-sets, they would revert back to what was set-up before I bought the '05 LT. Eventually, the battery was losing power so I put a BMW(gel) charger in the power point and called it a night. The next day I removed the charger and tried to set the stations again. This time when I pushed the "on" button, nothing showed up on the screen in the radio section, just the buttons on top of the tank lit up.
Thanks in advance,
Jeff
tazz56 is offline
post #2 of 5 Old Oct 2nd, 2006, 7:35 am
mneblett's Avatar
Thanks in advance,
Jeff
When you tried the radio in the morning, did you turn on the ignition? On my bike, a quick flick of the ignition to ON is required to get the radio to know it's "ok" to turn on (apparently, it resets the auto shut-off timer, enabling radio operation). If that's not it, post more symptoms/clues for us!
Mark Neblett
Fairfax, VA
mneblett is offline
post #3 of 5 Old Oct 5th, 2006, 3:01 am Thread Starter
tazz56's Avatar
Radio problem
Sorry it took me so long to get back, after all it's my question. All I know is:
1. The radio worked when I bought the bike.
2. I didn't like what the pre-set stations were set at.
3. I tried to re-set the stations w/o success. Maybe I didn't do correctly,
not sure.
4. Battery was getting low from all my attemps to change the station pre-
sets. I plugged in a BMW charger(gel), and charged overnight.
5. Next morning I turned the bike on and tried again. Nothing indicated on
screen for radio. Even tried after starting the bike, still nothing.
6. Frustrated, went for a ride. I don't use the radio much, but once in
I do. Plus it is a feature of the LT, so it's supposed to work.
Mark, I tried your suggestion but nothing changed. If the tank lights didn't come on I would think it's a fuse, but they do light up when I try to turn the radio on. I'm not mechanically inclined so maybe I'm just overlooking something simple, ( I hope).
thanks,
Jeff
tazz56 is offline
post #4 of 5 Old Oct 5th, 2006, 5:15 am
Woolly's Avatar
Disconnect the battery for 30 minutes, then re-connect it - the sound system gets confused occasionally.
After you have re connected the battery, turn the ignition on, then slowly open the throttle fully twice(twist the twist grip all the way round) - this resets the ECU. Good Luck.
  • MB SLK 350 MT
  • 1974 Triumph Bonneville 750
Woolly is offline
post #5 of 5 Old Oct 6th, 2006, 1:43 am Thread Starter
tazz56's Avatar
radio problem: solved
Thanks Brian! I disconnected the battery as instucted before around 4:30 pm(cst) before going to see Aerosmith & Motley Crue in concert. At 12:30 am I reconnected the battery, turned on the ignition, rolled the throttle all the way 4 times, and then the radio came on. I have to go for now but I'll be back to search for the best way to set the stations for what I want to hear.
Thanks Again,
Jeff
tazz56 is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Different radio problem hagar K1200LT 10 Sep 15th, 2006 12:03 pm
Very strange radio problem louatlvc K1200LT 4 Aug 14th, 2006 10:51 pm
Help With Radio Problem reds K1200LT 2 Jul 15th, 2006 10:37 pm
AM Radio problem RoyvL K1200LT 4 May 6th, 2006 8:07 pm
