Headlight Problem - BMW Luxury Touring Community
post #1 of 6 Old Sep 30th, 2006, 3:41 pm Thread Starter
mistral's Avatar
Question Headlight Problem
I have a 2001 LT. The low beam headlight has been working part time. I have had the high beam light on the dash light up when the high beam is not on. It is now staying on and both low and high do not work at all. Any ideas guys.
Thanks.
Ron
mistral is offline
post #2 of 6 Old Sep 30th, 2006, 3:56 pm
bmwrubbercow's Avatar
First, replace both bulbs. I think that will take care of it.
If not could be corroded headlight contacts or bad switch, etc. Most likely bulbs. Suggest PIAA Extreme white xenon blubs as replacements. Much more expensive but much more light. Approx $50 for the low beam and maybe as much as $80 for the high beam. Now, if you want to go to HID, you will have even better light, but with some additional cost for the parts plus some shop labor unless you can self-install. You should be able to simply change bulbs in 5 minutes or so.
(And just wait until you read the resulting comments as to my opinion of xenon bulbs!)
Good luck.
Tom
2003 R1150RT, Black Beauty--this is one sexy bike!
1999 R1100GSA, Does everything well, what else can one say?
1992 K75SA, If this engine had been 4-valve instead of 2, it would be the smoothest BMW ever built!
1978 R100S, my first and favorite BMW.
1976 R75/6, A 30 year old gentlemen I still love to take out for a Sunday ride.
bmwrubbercow is offline
post #3 of 6 Old Sep 30th, 2006, 4:18 pm
Senior Member (ret.)
RaffyK's Avatar
your ground wires to the hi-beam retainer inside the headlight are either loose or melted.
Raffy
RaffyK is offline
post #4 of 6 Old Oct 3rd, 2006, 8:06 am Thread Starter
mistral's Avatar
Talking
Thanks guys, it looks to be a loose wire. I appreciate the help!
Ron
mistral is offline
post #5 of 6 Old Oct 3rd, 2006, 9:16 am
KMC1's Avatar
Now that you're already in there, put in the HID.
(Down to ONE BIKE - ARGH!)
KMC1 is offline
post #6 of 6 Old Oct 3rd, 2006, 3:56 pm
ez_rdr55's Avatar
Headlight Problem
My '04 did this exact same thing. Turn the lights on, wait 30 seconds then try touching the ground wire with your bare hand. If you get the piss burned out of you it's the ground wire. Do NOT ask me how I know this. This problem is in the HOW. After I rewired the ground my lights are noticeably brighter.
ez_rdr55 is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 12:17 pm
Rain induced problem on '04 LT? bwdjr K1200LT 3 Nov 19th, 2009 12:01 pm
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 11:37 pm
Oil Usage Problem Solved..Finally herk402 K1200LT 7 Sep 26th, 2006 1:51 pm
