Radio!!!! - BMW Luxury Touring Community
post #1 of 6 Old Sep 30th, 2006, 11:37 am Thread Starter
Radio!!!!
I have had some troubles with my radio. It has power, it shows the stations, I can change stations using my seek button, but I have no sound.
I have taken all the connections apart and put them back to make sure they are connected properly. I still have no volume or sound from the speakers.
Anyone have any suggestions short of buying a new radio from BMW for $700?
Thnx
Darrell
gwhiz162000 is offline
post #2 of 6 Old Sep 30th, 2006, 12:56 pm
Just a suggestion that you have probably already tried. Press the musical note on the stingray (bottom row, second from the left) and cycle through the options and make sure that the speakers are set to on.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #3 of 6 Old Sep 30th, 2006, 3:14 pm
Talking
On my 02 I had no sound and checked in the box on the tank where the CD player is located. There is a button on the left that puts the sound through the speakers or through the intercom. Check this if you haven't already.
Dix42 is offline
post #4 of 6 Old Sep 30th, 2006, 3:32 pm
mneblett's Avatar
If this doesn't work, the next thing I'd check is the fuses -- including the one that is hidden at the back of the radio chassis. The radio gets powre from, IIRC, 3 sources. There can be power to operate the radio display unit, but if the fuse at the back of the radio's out, then the radio's amps won't have power.
Mark Neblett
Fairfax, VA
mneblett is offline
post #5 of 6 Old Oct 1st, 2006, 1:04 am
Shogun54's Avatar
I hope you checked the mute buttons ( BOTH of 'em ).
Brett
Get busy livin' or get busy dyin'!
2003 BMW K1200LTC "El Gato Grande"
1993 Suzuki GSXR1100W
1978 Suzuki GS1000C 'Project'
Shogun54 is offline
post #6 of 6 Old Oct 1st, 2006, 10:26 am
mneblett's Avatar
Good to always check the basics -- the display should read "MUTE" if this is the case, so it's easy to check. Also, no need to check both switches -- they are momentary-contact switches, so they don't "lock" into place; either one can disengage the mute function with a single tap.
Mark Neblett
Fairfax, VA
mneblett is offline
Radio just quit atps1234 K1200LT 62 May 29th, 2017 11:43 pm
Radio static fixed (or "Curses, foiled again.") wcarter K1200LT 8 Dec 31st, 2008 8:37 pm
Bizarre Radio & Elec. Centerstand Behavior atps1234 K1200LT 12 Jul 10th, 2006 9:30 pm
Radio flickering KMC1 K1200LT 3 Jun 7th, 2006 11:50 pm
