Reverse Trouble .... - BMW Luxury Touring Community
post #1 of 7 Old Sep 28th, 2006, 10:15 pm Thread Starter
Today my LT faltered when I attempted to back into a parking space. I flipped the transmission into reverse, pushed the starter switch and bike failed to back up. The bike made a couple of small jerks rearward, then stopped in its tracks. I disengaged the reverse, checked everything over, then tried reverse again. The LT began to back up, but it felt like something was binding up somewhere. Have anyone else had this type of problem?
WalterBresnahan is offline
post #2 of 7 Old Sep 28th, 2006, 10:30 pm
yup. my 2005 is going in for service for that problem in a couple weeks. Probably the "reverser" relay they think.. after the battery failed.
J.M.J...
Dcn Channing
post #3 of 7 Old Sep 28th, 2006, 10:58 pm Thread Starter
Could you please email me when you find out what the problem is? I can not send my LT into the shop yet, as my truck in having some body work where a deer tried to run through the front fender.
post #4 of 7 Old Sep 29th, 2006, 8:59 am
Sure, will do... It goes in Oct 04th.
J.M.J...
Dcn Channing
post #5 of 7 Old Sep 29th, 2006, 9:53 am
What I did was.
My LT did that one time; Upon looking around on this site I found that some people fix the problem by looking at the reverse wires, bottom line on the right side of the bike, remove the fairing, right above the rear brake lever, below the gaz tank, wedge in between the gaz tank and the crash bar is a yellow wire, that wire is tight and wedged in there so good that it gets pinched, mine was pinched to the point of cracking the insulation, but the wire was intact so I re-routed it a little bit, slap a couple of rounds of black electrical tape and voila the reverse started working fine after that.
Something you might want to try before taking it in to the Techs.
Darcy Bastos
2007 FJR1300
2007 Ducati GT1000 Sport Classic
Atlanta, GA
ATLDB is offline
post #6 of 7 Old Oct 6th, 2006, 12:44 am
Problem diagnosed... seems the tranny interlock switch went north... that's easy fix... now it will be next week before the parts arrive for the faulty locking/alarm system.
J.M.J...
Dcn Channing
post #7 of 7 Old Oct 6th, 2006, 4:40 pm
Dead Battery and Bad Reverser
I had a similar problem on my 05 Lt. I posted a message about a year ago.
My battery would go dead, CC BMW in Metuchen, NJ found that my reverser had gone bad and was draining the battery. First they thought it was a relay and then decided that it was a reverser. It took 2 weeks to get the part from the motherland!
After the replacement no problems at all!
My main concern was that with a low battery would my ABS fail. Thank goodness I had no problem!
PhilD is offline
reverse wires and a couple other items tmgs K1200LT 11 Jul 21st, 2006 10:19 pm
Trouble with Reverse Enagement redfisher K1200LT 7 Apr 28th, 2006 2:03 pm
Ari’s winter farkle projects, part 1 (reverse radar) pozo_izquierdo K1200LT 17 Apr 9th, 2006 8:44 pm
just a couple of questions; reverse, etc. saileyboy K1200LT 9 Jan 7th, 2006 8:06 pm
LT Reverse distance Hitman_LT K1200LT 10 Dec 30th, 2005 11:39 pm
