Ever Used An Air Wrench To Remove Swingarm? - BMW Luxury Touring Community
post #1 of 12 Old Sep 27th, 2006, 9:18 pm Thread Starter
cccpastorjack's Avatar
I have read all the posts on trying to remove the swingarm pivot bolt and how tough that can be. Some even suggested using a 4-foot pipe as an extension on a 3/4 inch pullbar. QUESTION: Has anyone ever tried using an air wrench to "zap" them off?
Also, the manual does not describe (or even call for) "phasing" the drive shaft. Many in the threads said they know the procedure for marking and doing this. Anyone who would share that procedure?
Thanks so much!
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #2 of 12 Old Sep 27th, 2006, 9:23 pm
I don't think I would do that. Where have you been? You missed kevincook's great post on swing arm removal (title is "slave drilling procedure"). Just one page back in time. Give it a read.
post #3 of 12 Old Sep 27th, 2006, 9:32 pm
DGM
I tried the air wrench, no joy to break it loose. Also it was ok to help put the swing arm back on .but not to torque it.
I've had mine off for the slave valve and clutch replacement and there is nothing better than an 6 foot piece of pipe.
DGM is offline
post #4 of 12 Old Sep 27th, 2006, 9:34 pm
kevincook's Avatar
Jack,
This post might help you out. I'm going to updated it with some suggestions I have received but they are pretty minor.
http://www.bmwlt.com/forums/showthread.php?t=14595
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #5 of 12 Old Sep 27th, 2006, 9:52 pm Thread Starter
Thanks Guys - I Have All I Need
This place is great. Thanks for the quick feedback. God bless!
Jack Homesley
Cornelius, NC USA
post #6 of 12 Old Sep 29th, 2006, 12:32 am
A standard impact wrench may or may not help, I've had mixed luck. You'll need a heavy duty unit and a good air supply. If you don't have that it's the old breaker bar. Use a heavy duty one, perhaps a 3/4" drive with a 1/2" adaptor, it can take an amazing amount of effort to break the pivot pins loose ( may take a 4 foot pipe to get the leverage needed). It's worse if loctite has been used.
mjordans2000 is offline
post #7 of 12 Old Sep 29th, 2006, 5:28 am
Prodigal Son
early1's Avatar
Wink Wimps
Originally Posted by DGM
I I've had mine off for the slave valve and clutch replacement and there is nothing better than an 6 foot piece of pipe.
I keep hearing about this pipe thing . I have only had two off, one was a "sweat popper" , the other not a big deal.
Guess I'll get a "cheater pipe" for the next one (just in case).
ed early
Life is a Blind Curve , Just Ride It, Low and Inside
'00' Canyon Red
early1 is offline
post #8 of 12 Old Sep 29th, 2006, 9:57 pm
DGM
Smile
Ed.
I only weigh 150. the pipe helps so I don't have to hurt myself. 27 years of working on helicopters has taught me a few lessons,
DGM is offline
post #9 of 12 Old Sep 29th, 2006, 10:13 pm
Cool
Jack
I found that a good impact gun works the best on removal.
My first removal with pipe and breaker bar ended up with stripped pivot pin trying to remove differential.
Had to remove swingarm and take to machine shop to drill out and retap. the other pins came out just fine with a MAC Tools impact wrench.
Does anyone know what metal is used for pivot pins, I tried to torch pin but was not able get hot enough ?
2002 K1200LT
reds is offline
post #10 of 12 Old Sep 30th, 2006, 12:35 am Thread Starter
Great Input!
I was just wondering why it wouldn't work for removal only of course. I have a Snap On Air Wrench that applies 650 ft lbs of torque in reverse, so I was just wondering why it couldn't be used and it would seem that it should just take it right off. We'll seeeee...sure don't wanna round that sucker!
Jack Homesley
Cornelius, NC USA
post #11 of 12 Old Sep 30th, 2006, 3:11 pm
If you have 650 lbs in reverse that should do the job. Mine can reach that but my big compressor needs a new motor, the smaller one can't provide enough air.
post #12 of 12 Old Sep 30th, 2006, 9:41 pm
Prodigal Son
early1's Avatar
Talking Ok--
Ed.
--so us FAT guys have at least an advantage at somethin'
ed early
'00' Canyon Red
early1 is offline
tech question on how much tupperware to remove rando K1200LT 8 Aug 23rd, 2006 8:04 am
Ohlins shocks sanjaun2 Shocks and Suspension 35 Jul 16th, 2006 3:01 am
Torque Wrench: Need One, Please Advise hschisler K1200LT 23 Jun 16th, 2006 9:51 pm
What size torx drive do I need to remove tupperware? KayGee K1200LT 6 Nov 27th, 2005 1:20 am
