brake warning light - BMW Luxury Touring Community
post #1 of 1 Old Sep 26th, 2006, 4:23 pm Thread Starter
bikesnumbnuts's Avatar
brake warning light
Took the wife away last weekend and headed for the lake district .
heavy rain most of the way when all of a sudden the brake warning light came on , so i stopped and switched the ignition off and then switched back on again. 20 miles further and it came on again , so i repeated again and all okay until i noticed that when i used the rear brake the light came on again .
stright away i thought maybe the fluid is low and after a check it was on the max line . so i then checked to see if one of the bulbs was blown or a loose connection on the rear light was the cause , but everything was okay , so monday last i rang my dealer and he told me to bring it in and they would hook it up and check the stored memory for faults .
The outcome was a faulty rear brake light switch which water had got in and caused this problem , but once dried out it was okay.
dealers gonna change it for a new one under extended warranty .
has any body had a problem with water in this switch before , and can i prevent this happening again ?.
bikesnumbnuts
04 your 05 graphite
in blighty
bikesnumbnuts is offline
How many of us does it take to change a light bulb?! Bruce_Yates Humor 4 Mar 1st, 2006 9:03 am
How many forum members does it take to change a light bulb? RoyvL Humor 12 Feb 13th, 2006 1:49 pm
Brake Failure Warning Light rglassma K1200LT 10 Feb 7th, 2006 10:13 am
Brake Light Switch jeffklt K1200LT 7 Nov 15th, 2005 3:24 pm
Brake Light On gunny K1200LT 2 Oct 27th, 2005 10:38 pm
