2002 k1200lt ABS Unit - BMW Luxury Touring Community
 1Likes
  • 1 Post By beech
post #1 of 5 Old Feb 29th, 2016, 7:53 pm Thread Starter
Need help getting ABS unit out of bike. The repair manual I have does not tell how to get out. Wondering what will happen if I remove the two frame bolts at engine? What's a good repair manual that gives good detail? Thanks for any help.
Sjgolden is offline
post #2 of 5 Old Feb 29th, 2016, 8:38 pm
want2tour's Avatar
Re: 2002 k1200lt ABS Unit
What manual are you working with at this juncture?
2005 KLT Graphite Gray
2003 F650GS Black
*Too slow for fast women
want2tour is offline
post #3 of 5 Old Mar 1st, 2016, 12:30 am
beech's Avatar
Here is some interesting reading on that module and the fight others are having:
Module Master has started repairing iABS - I-BMW.com
It is a common problem and Module masters in Idaho have not started repairing them. There is a shop in Germany that will.
Steuergeräte Reparatur für Ihr Motorsteuergerät
About $700 plus postage each way.
Just hard work getting it out. Many bike systems will not work with out the PC board that is in the side of the unit. Some folks plate seal the electronic unit if it is okay and remove the ABS by jumpering hoses.
cbpip likes this.
Beech
beech is offline
post #4 of 5 Old Mar 1st, 2016, 6:49 pm
You don't need to remove any frame bolts but you do have to remove the Reverser controller (The silver block to the rear of the ABS). Your picture is on the wrong side of the bike for the ABS unit. There is a cradle that holds it in place and once you get those connectors off and reverser out of the way you should be able to see the fasteners. The last bit is from the BMW manual.
ID:	99225   Click image for larger version
post #5 of 5 Old Mar 1st, 2016, 7:43 pm
rosmba's Avatar
I am convinced that if my ABS fails I'll just part this bike out and go back to a Harley.
Rick Smith
Hagerstown, MD
rosmba is offline
Permantly Disable K1200LT ABS jsphillbiker K1200LT 25 Sep 7th, 2018 11:11 am
2005 k1200lt abs questions pdrrock K1200LT 22 Jan 4th, 2015 9:21 pm
2005 K1200LT ABS Question boblouder K1200LT 20 Jan 5th, 2014 9:51 pm
2002 K1200LT Electrical Gremlins and Other Adventures bmwollman K1200LT 15 Dec 29th, 2013 10:16 pm
ABS control unit failure relating to Speedometer Operation LTRiderAZ K1200LT 8 Sep 21st, 2011 6:48 pm
