2000 KLT Clutch "How do these parts Look" ?? - BMW Luxury Touring Community
 6Likes
  • 1 Post By mcracer
  • 2 Post By bmwcoolk1200
  • 1 Post By bmwcoolk1200
  • 1 Post By jzeiler
post #1 of 11 Old Feb 27th, 2016, 3:47 pm Thread Starter
mcracer's Avatar
I pulled these parts out of my (New to Me) 2000 KLT with 54K on the odometer. I don't see any RED FLAGS. There is a "GLASSY" look to the steel plates, some dis-coloration, you can still see the original mill marks from when it was machined new. Everything is TRUE (flat).
Fiction Plate measures .225 inches. (That's 5.715 mm) Service limit in Clymer is .181 inches. (That's 4.597 mm) New measures 6.0 mm.
The Numbers; Current wear = .285 mm, Remaining life to service limit = 1.118 mm.
By those numbers, this clutch is at approximately one quarter 1/4 life gone at 54K miles.
Name:	DSCN0762 (1024x768).jpg
ID:	98945   Click image for larger version
Name:	DSCN0763 (1024x768).jpg
ID:	98953   Click image for larger version
Name:	DSCN0767 (1024x768).jpg
ID:	98961   Click image for larger version
Name:	DSCN0770 (1024x768).jpg
ID:	98969   Click image for larger version
Name:	DSCN0771 (1024x768).jpg
Name:	DSCN0773 (1024x768).jpg
ID:	98985   Click image for larger version
Name:	DSCN0774 (1024x768).jpg
mcracer is offline
post #2 of 11 Old Feb 27th, 2016, 4:14 pm
bmwcoolk1200's Avatar
Re: 2000 KLT Clutch "How do these parts Look" ??
If they really are flat, that is great. Mine had a couple thousandths dishing also at 56K but I re-used them.
This isn't mine but it is an example of the uneven wear usually encountered and what to look for. Mainly for those following along planning to do this any time soon.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 11 Old Feb 27th, 2016, 4:59 pm Thread Starter
mcracer's Avatar
After CLOSER inspection. The PRESSURE Plate is showing .005 inch of wear on the inside edge with a straight edge across the entire distance. .005 inch at inner most point, tappers out to nil. .0025 half way across the surface. Seems very even, slight discoloration on inner 1/4", where the wear is the most (.005 in).
sailor likes this.
mcracer is offline
post #4 of 11 Old Feb 27th, 2016, 6:41 pm
That looks very much like mine Mark. Smallest gauge I had was 8 thousandths and it wouldn't go under my straight edge so I am also probably at around 4 to 5 thousandths wear in the inner edge. I am not saying to use them but I did with a new spring plate. I have not had it up under a high speed 2 up load or out of my neighborhood yet but I did do some checking to see if it would slip and so far, it is good. I suspect as the outer edge wears a thousandth or so, the pressure will even out. Long story short, I may have less life out of this new oil resistant friction plate than if I had replaced the pressure plate and cover but I am not a hot rod stressing it out at every turn so I expect I will get " acceptable" wear and life from it. Bottom line, you will have less contact area across the friction disk face and accelerated wear at the outer contact edge until it catches up but that friction material will be gone forever. My disk at its thinest is .216 thousandtns or .00548mm. Good news is the new disk doesn't have any rivets to run into Keep posting your pictures, I have seen a large number of these K bikes needing this recently so many are watching with interest.
ID:	99049   Click image for larger version
Patric and mcracer like this.
Gordon
Sugar Hill, GA
post #5 of 11 Old Feb 27th, 2016, 7:28 pm
I think I see an oily clutch in two photos, that's a red flag! I'm doing the same job right now on my 2002. These bikes are 15 plus years old and the seals, regardless of miles are probably at the end of their serviceable life. For my bike I bought all new parts except for the aluminum housing. A big bite of cash but much less than the $3200 my dealer wanted! I saved some money ordering the Siebenrock oil "resistant" clutch from Hornig. (https://www.motorcycleparts-hornig.c...sistant-4.html)
Strong USD helps here and you don't pay VAT, which is more than shipping cost. Heck, I'm saving so much I bought the motorcycle lift from Harbor Freight for 240.00 plus tax! It's nice to stand up and work. Good luck with your clutch job and I hope to see you on the road!
CheezNbeer is offline
post #6 of 11 Old Feb 27th, 2016, 9:47 pm
I also got the HF lift to do this job but replaced the inadequate wheel clamp with something better. Just make sure that when raising the back end either when dropping the trans or just raising it to get stands under it in plans of lowering the motor that you take into account that your straps holding the front of the bike will need to be adjusted. DO THIS CAREFULLY and at the lowest lift position as you don't want to dump the bike
My HF wheel clamp is still in bubble wrap. I never intended to use it. I have something much more substantial. You have to use the reverse on such a heavy bike to get it back out though .
radar41 likes this.
Gordon
Sugar Hill, GA
post #7 of 11 Old Feb 28th, 2016, 8:10 am
rattler50's Avatar
I couldn't get the pics to load. I wanted to see the pressure plate to see if it had any "hot spots" on it that look like metal smears. If it does, it needs replaced. Once that metal is moved, it becomes a problem if it gets hot again. I changed the clutch disc on mine
kept the pressure plate because it was clean. It's a lot of work to get in there. I wouldn't put an old disc back in.
2006 R1200RT
2005 K1200LT Ocean Blue
2003 K1200LTE Black
Totaled Oct 2, 2010
2006 Kawasaki Vulcan 2000
rattler50 is offline
post #8 of 11 Old Feb 28th, 2016, 8:26 am
rattler50's Avatar
I misunderstood your post. I thought you were asking if any of it was good enough to be reused. My bad. The clutch disc looks like mine did after the slave leaked on it. Some of the fibers were missing and it had the burnt clutch glaze on it. Looks like they may have caught it early and went ahead and run it. Does it have the weep hole drilled under the slave? If so, that would be my guess.
2006 R1200RT
2003 K1200LTE Black
Totaled Oct 2, 2010
post #9 of 11 Old Feb 28th, 2016, 10:24 am Thread Starter
mcracer's Avatar
This is the first time I ever saw one coming out. All the pic I find are of the NEW clutches going IN. I was wondering if this is OIL contaminated? It is black-ish. AND there has been oil leaking from seals. Both; Trans input seal and Engine Rear Main leaking (New parts going In). The dust is not powdery dry but not sticky wet either. ??
BTW; The Clutch Slave is not leaking. This is not a slave cylinder failure. New Slave is going in also, because it's time!
ID:	99089   Click image for larger version
mcracer is offline
post #10 of 11 Old Feb 28th, 2016, 10:29 am
That is what I had on my LT. Not wet but not completely dry. Main suspect was the o-ring on the clutch housing where it is held on the output shaft. (also based on what I see on you pic of the housing) The main seal leak will never make it into the clutch unless the bell housing fills with oil.
mcracer likes this.
post #11 of 11 Old Feb 28th, 2016, 12:12 pm
That was the only part of my job that I didn't photograph. Mine had the same stuff around the inside of the bellhousing. It smeared when you wiped your finger across it so there was at least some component of oil in it. The streaks inside Marks clutch basket also look like the O-ring was marginal and failing. I managed to get mine out in one piece but it was hard as a rock.
mcracer likes this.
Gordon
Sugar Hill, GA
Clutch Parts and Pics whdunn4 K1200LT 2 Jan 2nd, 2012 2:22 pm
Unreliable clutch advice please cyclecamper K1200LT 11 Dec 1st, 2008 10:23 pm
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 9:00 pm
