$350 Valve Check - BMW Luxury Touring Community
post #1 of 20 Old Sep 25th, 2006, 2:03 pm Thread Starter
Dochatley's Avatar
$350 Valve Check
Yes, you are reading that right. I was at the dealer in Dallas Sat. to pick up a new battery (trying to support my dealer) and I ask him "how much to get the valves checked". He yelled back at the mechanic and was told $350 dollars. I asked if I brought it in with the plastic off if it would be a little cheaper. He said no not really. I know it is not hard to do but having never checked them I am a little apprehensive about checking them for the first time. But $350.00. OUCH, bend over.
If you want to make God laugh, tell him your plans
Jerry P. Hatley
2007 R1200RT (Betty Lou)
2009 Harley Roadglide (sold)
2007 Goldwing (sold)
1999 BMW K1200LT (sold)
2004 Harley Ultra Classic (sold)
2002 Harley Ultra Classic (sold)
1998 Harley Roadking Classic (sold)
Dochatley is offline
post #2 of 20 Old Sep 25th, 2006, 2:31 pm
Daveh's Avatar
The valve check and adjustment article at gunsmoke.com makes the job easy!
2003 K1200LTC Titan Silver
BMWBMW, BMWMOA, AMA, IBA
Daveh is offline
post #3 of 20 Old Sep 25th, 2006, 2:46 pm Thread Starter
Dochatley's Avatar
Thanks Dave. I have read over it several times for the last few months and it sounds pretty straight forward. I guess maybe once I got in there it might make more since. I have done all other maintenance with no trouble but this seems scary
Jerry P. Hatley
post #4 of 20 Old Sep 25th, 2006, 3:00 pm
zimbazi's Avatar
Jerry,
Save your $$ I will be in Fort Worth to go Dancing this Saturday night.
If you want some help I could stop by ?
It is like eating a stack of pancakes...
We did four bikes in the tech session here in austin.
The last bike took less than one hour from beginning to end.
Just send me a PM before thursday with your information...Phone # and Address?
I do NOT work on Fridays and rarely check the forum over the weekends...
Jeff Goodwin
Austin, Texas
"Life is a coin.
You can spend it anyway you wish,
but you can only spend it once."
zimbazi is offline
post #5 of 20 Old Sep 25th, 2006, 3:16 pm
BLBantz's Avatar
Had mine checked last week at my local BMW dealer. $140.00
Brian
Fanwood, NJ
2003 K1200LT Anthracite
BLBantz is offline
post #6 of 20 Old Sep 25th, 2006, 8:19 pm
BecketMa's Avatar
For me, the hardest part was installing the new valve cover gasket. I was concerned that it might leak. Probably shell shock from many leaking HD valve cover gaskets.
It was pretty easy to turn the engine over by pushing on the rear wheel with my foot, when it was in 5th.
I bought a new feeler gauge, and made sure I had the proper gasket seal material.
With the advent of MP3 players, I had enjoyable music to listen to as I slowly went through the procedure. Did mine during normal change and check.
BecketMa is offline
post #7 of 20 Old Sep 26th, 2006, 10:35 am Thread Starter
Dochatley's Avatar
Thanks for the offer Jeff. I still have a couple of thousand miles before it's time (that is if the dealer really checked them before I bought this bike used). I guess I will start ordering the stuff I need and give it a go. Heck if I come to a roadblock I know where to come for answers. Thank you again Jeff for the offer.
Jerry P. Hatley
post #8 of 20 Old Sep 26th, 2006, 12:47 pm
LT valve check
Jerry, after you do the valve check you will be shouting.."Man this is a piece of cake!" It's really that easy! In fact it will take you twice as long to take off the plastic as it does to do the valve check. Word to the Wise: make sure you write down the clearances once you check the gaps! next time you check the valves you'll have a "standard" to cross check to see if things have changed. Also, I marked the inside of each screw hole in each plastic piece with a S, M, or L which stands for short , medium , and Long ( screws that is!) It also helps to have 3 cups for the screws to keep them separated.
Good luck and don't spend all that money you will be saving in one place!
Ron Ray
ronlray is offline
post #9 of 20 Old Sep 26th, 2006, 1:59 pm
It's been a long time since I had a dealer do work on my bike but with the plastic off they also charged me a little less than 150.00 to check the valves. In fact, I believe they actually did an adjustment at that time (for some reason the invoice was not very detailed but the mechanics checklist showed a change).
mjordans2000 is offline
post #10 of 20 Old Sep 26th, 2006, 3:04 pm Thread Starter
Dochatley's Avatar
Thanks Ron Ray....I will take your advice. Some how all those short/long screws get all mixed up when it is time to put her back together. I am going to copy the chart that was on one of the threads not to long ago to keep up with clearances.
Jerry P. Hatley
post #11 of 20 Old Sep 26th, 2006, 4:49 pm
Shogun54's Avatar
Jerry, you won't need parts unless they need adjustment. A little care removing the valve cover gets the gasket off intact nearly every time. If you need buckets, you'll have to buy them after calculating the size...you may find they are all OK.
Brett
Get busy livin' or get busy dyin'!
2003 BMW K1200LTC "El Gato Grande"
1993 Suzuki GSXR1100W
1978 Suzuki GS1000C 'Project'
Shogun54 is offline
post #12 of 20 Old Sep 27th, 2006, 3:42 am
BecketMa's Avatar
I taped my valve clearance paper to the side on my tool box.
Try a little nail polish on the screws and a little dab on the on the hole they come out of.
BecketMa is offline
post #13 of 20 Old Sep 27th, 2006, 12:24 pm Thread Starter
Dochatley's Avatar
Great idea Bob. My wife has about 50 bottles in a basket in the bathroom that she NEVER uses. Keeps them "just in case". Of what I don't know.
Jerry P. Hatley
post #14 of 20 Old Sep 27th, 2006, 1:54 pm
dpaz's Avatar
Smile
Is the procedure to check the valves on a K1200LT the same as a K1200RS? I am new to this and I am starting to do my homework on it before I tackle it. I am reading the procedure found on gunsmoke.com under the K1200RS section. Thanks again,
dpaz
David
2003 K1200 LTC Anthracite
dpaz is offline
post #15 of 20 Old Sep 27th, 2006, 2:00 pm
Daveh's Avatar
Yes, the valve check is the same for the K1200LT as the K1200RS.
Daveh is offline
post #16 of 20 Old Sep 27th, 2006, 2:28 pm
dpaz
There is a BIG error in the gunsmoke procedure. DO NOT remove the spark plugs before doing any measurements! That is very important. If any dislodged carbon particles from plug removal drop down onto the valve face or seat surface of any open exhaust valves, incorrect clearance measurements will be the result.
post #17 of 20 Old Sep 27th, 2006, 4:39 pm
Valves
Jerry
Am presently doing my valve checks on k1200lt 2003, followed Gunsmoke instructions, have previously done same task on k1100lt, it really is quite basic, before you start, buy a decent torque wrench & use it, you will find that the standard of work you have recieved previously at dealers workshops, may not have lived up to your expectations, i found a stripped thread on the cam cover, if dealer had used correct settings i should not have found that. some jobs are best left to dealers, this is not one of them, you can also get the settings you want, not just that old chestnut, its in tolerance??.
Good luck
Regards Stevie
stevie1 is offline
post #18 of 20 Old Sep 27th, 2006, 5:02 pm Thread Starter
Dochatley's Avatar
Thanks Stevie. I did get a torque wrench when I started to do my own wheel removal. I was shocked when I torqued the front tire. The setting is 30nm on the main axle if I remember correctly which isn't much. Without that wrench I would of tightened it a lot harder as I did most stuff.
Jerry P. Hatley
post #19 of 20 Old Sep 27th, 2006, 7:13 pm
myk_edwards's Avatar
She kept them for you! now all you have to do it choose a nice colour or three to mark up them screws.
Rgds
"For those that know, no explanation is needed,
For those that don't, no explanation is possible."
2001 K12 LT Toscana Green AKA Baby Sh*t Green
Kawasaki EN500 - been sold on!
Hardtail Chopper ( Honda CB 500 engine) in a box still!
myk_edwards is offline
post #20 of 20 Old Sep 28th, 2006, 2:48 am
dpaz's Avatar
Thanks for the info guys. I will not remove the plugs. Thanks for the warning.
David
dpaz is offline
Valve cover gasket sealant REWDOC K1200LT 20 Jul 22nd, 2006 9:06 pm
Outcome of Valve check? artk50 North West 18 Apr 26th, 2006 11:44 am
The Scphincter Valve DaFlake Humor 1 Apr 6th, 2006 1:46 pm
Need Help Finding Kawasaki 1000 Specs S2DOG Chit Chat 4 Jan 18th, 2006 7:45 am
2nd failure of the rear wheel tyre valve PhillWard Australia, New Zealand, and AsiaPac 4 Oct 31st, 2005 11:03 pm
