Fuel line in tank - BMW Luxury Touring Community
 4Likes
  • 1 Post By mcracer
  • 1 Post By bmwcoolk1200
  • 1 Post By Gdrdocbmw
post #1 of 21 Old Feb 21st, 2016, 2:25 pm Thread Starter
Fuel line in tank
Hello,
Getting parts lined up for spring maintenance. I have been unable to find the fuel lines in the fuel tank. I have a 2005 K1200LT. Also what clamps should I use?
thanks
Steve
stevekremer is offline
post #2 of 21 Old Feb 21st, 2016, 7:25 pm
mcracer's Avatar
Re: Fuel line in tank
MAX BMW fiche shows what's inside the tank. Part #4 and #6 on the list ($25 and $39 respectively). Personally, that bike isn't old enough for that single piece of rubber hose to be replaced. It's expensive so if you want too... They are made to sit in gasoline, never has any UV exposure and not something I am worried about. BMW maintenance schedules are intense BUT, they would have you replace the engine at 100K because it's on the schedule. Unless there is a problem when you change the fuel filter, move on. Clamps can be small screw type, stainless-steel. My 2-cents.
LINK to parts fiche;
MAX BMW Motorcycles - BMW Parts & Technical Diagrams - K1200LT 99-04 (89V3)
mcracer is offline
post #3 of 21 Old Feb 21st, 2016, 8:30 pm
JNW003's Avatar
I would replace the fuel lines inside the tank at the same time that I changed the fuel and air filters and use Oeticker stainless steel clamps on the fuel lines, since the bike is 11 years old. Several other LT owners have written in earlier threads about screw type clamps popping off in this hard-to-get-to location. I changed my '07's last summer for peace of mind, since I had the tupperware and tank off anyway.
One other thing I would recommend, if it hasn't been done already, is to change the quick disconnects on the fuel lines, as the factory versions tend to fail at inopportune times. Beemer Boneyard sells a popular version, and others (myself included) use JiffyTite QDs.
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #4 of 21 Old Feb 21st, 2016, 9:03 pm
norton's Avatar
The in tank fuel lines should be changed. You can buy a 12" piece of submersible high pressure hose from any auto parts store for $15 to $20. which is what I did and it works fine to replace both in tank hoses. The fuel line metal quick disconnects should be done also. Another smart and safe change should be your brake lines as BMW rubber lines internally deteriorate and will clog your ABS unit and cause a failure.
Good Luck with your maintenance.
Scott
2007 LT
norton is offline
post #5 of 21 Old Feb 21st, 2016, 11:33 pm
Moogie's Avatar
The Boneyard sells these. I think some members are using them. I've got them but haven't used them yet.Fuel line in tank-flexible-tank-fuel-hose-kit-4.jpg
2000 Lt
800 Kawasaki
25 yrs. without
750 Suzuki
550 Suzuki
160 Honda
Moogie is offline
post #6 of 21 Old Feb 22nd, 2016, 7:25 am
Well, my u-hose didn't know this as it failed after seven years and less than 50,000 miles (2014 failure on my 07 LT). It failed the morning after I returned from a 5,000 mile trip to Nova Scotia and Newfoundland. I was 1/4 mile down my driveway when the bike sputtered and died. I was quite glad it hadn't failed at Meat Cove or Gros Morne.
I replaced with OEM hose and screw clamps from BBY. I debated getting the Oetikers and tool to install them, but it seemed wasteful since I already carry screwdrivers and I like being able to do roadside repairs with as few special tools as possible. And I have used screw clamps on everything from cars to semis to airplanes for 40 years without failure. Mine are holding up well on both the QDs (7 years) and the u-hose (2 years).
I would absolutely replace a more than 10 year old in-tank hose and I would use whichever clamp gives you peace of mind. Oetikers are more idiot-proof to install and installation errors are the most common cause of clamp failure. Most grossly over tighten screw clamps damaging the hose. You should tighten the screw just enough to get the OD of the clamp about equal to the OD of the hose. That is, the amount of hose compression should equal the thickness of the clamp band.
post #7 of 21 Old Feb 22nd, 2016, 10:36 am
mcracer's Avatar
I'm paying attention! Old Saying "You don't Know what you don't Know". Since I'm already into this KLT for a Pound; What's a Penny more? I just ordered some lines from EURO MOTOELECTRICS;
EnDuraLast - K Fuel Pump Hose Kit
and will change them out with the new filter as things get put back together. Stumbled on to this supplier here in Denver while reading old posts on 'Fuel Lines", Local pick-up. I get "Piece Of Mind" Thanks
mstrquad likes this.
mcracer is offline
post #8 of 21 Old Feb 22nd, 2016, 12:33 pm
beech's Avatar
There is such a thing as fuel injection rated screw hose clamp. Don't use the regular worm type. Here is an example:
Amazon.com: AAS 3/8" Fuel Injection Hose Clamps FI8 (Pack of 10) 9/16" - 5/8" Dia: Automotive
These in the tank hoses need to be very snug. You would be surprised how easy they can pop off. And as the man said for the straight hose runs use immersion approve high pressure (fuel injection rated) hose. For the pre shaped pieces buy the BMW OEM hose. It is difficult to find metric hose, the SAE inch stuff works, but I just bite it and get all OEM for no worries. And don't head out on a vacation the day after this job. Ride around for a week!
Beech
beech is offline
post #9 of 21 Old Feb 22nd, 2016, 3:50 pm
bmwcoolk1200's Avatar
Mark, you and I are a lot alike.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #10 of 21 Old Feb 22nd, 2016, 5:36 pm Thread Starter
Thanks for all the info and the links
Steve
post #11 of 21 Old Mar 11th, 2018, 6:54 am
anarchosteff's Avatar
I currently have my fuel tank off for some gear-box/clutch/main-seal repairs, and it would be silly not to do the fuel filter and in-tank fuel lines while I'm there. I've had the bike for 4-years, and given the lack of maintenance I've seen thus far I don't imagine the fuel lines have ever been replaced, let alone the fuel filter.
These days, the U-shaped fuel line is running about $47 and the L-shaped fuel line about $32. Rather than spending $90 on fuel lines, this kit from BBY is looking pretty attractive at $13 https://www.beemerboneyard.com/subhosekit.html
At 10" long the center section of the line looks to be about 5". If I leave about .75" inch at either end for the provided fuel-injection style hose clamps, I'm at 6.5" total on the U-shaped line, which seems not too excessive. The L-shaped line doesn't look to be 5" though. Can I use a 2.5" hunk of straight fuel line on either end of one of these replacement lines to do the L-shaped?
Anybody have a pic of using this kit? ... or is my attempt to save $77 here a bad idea?
-Steve
Titusville, FL
anarchosteff is offline
post #12 of 21 Old Mar 11th, 2018, 7:17 am
-Steve
Titusville, FL
I didn't do a thorough enough search the first time. Looks like this answers my question in the affirmative: http://www.bmwlt.com/forums/k1200lt/...ml#post1046777
post #13 of 21 Old Mar 11th, 2018, 8:23 am
Steve, I have this kit on my LT. Here is a view outside and inside. I would say some care would need to be taken when reinstalling the pump assembly so that the hoses which the longer nylon one will be a bigger loop than the rubber molded so that it does not impact the inside of the tank. If the pump flange was installed slightly twisted, it may hit and rub on the inside. the second pic is a view from the fuel level sending tube hole to be sure I had it clear inside of any impact.
ID:	140833   Click image for larger version
anarchosteff likes this.
Gordon
Sugar Hill, GA
post #14 of 21 Old Nov 30th, 2018, 3:44 pm
I just sent my seat to Russell for their magic and put the LT on the lift for winter maintenance. I plan to replace the fuel filter and my U-hose is now 5 years old so planning to replace that also with the nylon parts. When you did your short hose in the first picture, it appears to have no corrugations. Was this part you cut off one end of the hose? Or did you find a place to buy hose with no corrugated?
post #15 of 21 Old Nov 30th, 2018, 4:49 pm
Matt, you probably don't want any corrugated parts under the clamps. The ones I received had enough straight portion on each end to cut the short piece and still leave enough for the clamp before you hit the corrugated portion. If I were doing it again and I will have to, I would cut both ends and slide the corrugated part further down on the filter to ease that funky bend I have because the end is too long to slide any further down as I did it. As Sailor said, just go slow in putting them over the tubes so not to stress or split it. If you get what I got, one hose is good for the entire job and you will have a spare if you ever need it.
Gordon
Sugar Hill, GA
post #16 of 21 Old Nov 30th, 2018, 5:55 pm
Yes, I wanted to avoid having the corrugated portion under a clamp. That is why I was wondering where you got the straight piece. Did you get yours from BBY or Euro Motolectric? Looks like the same thing, but hard to be sure.
I was thinking that a little heat from a hair dryer might be an installation aid.
post #17 of 21 Old Nov 30th, 2018, 6:24 pm
sailor's Avatar
Not sure where Gordon got his, but I got my set from EuroMoto about 3 years ago - this was just before BeemerBoneyard started selling these (although I have NOT compared both sources for identical contents).
I am still riding with same installation I did about 2 1/2 years ago:
(1) the straight part at each end of corrugated hose was cut so as to keep just enough to go over the metal part of filter and flange assy metal tube. Did not take a photo but it was something like 0.65 inch (5/8 roughly) to go over the hump in metal and be able to install screw clamp furnished with it.
Cutting both ends to minimum also led to much less spare hose doing an abnormal long curvature inside tank (compare to factory stock 180 degree short section)
(2) To replace short straight section of hose below fuel filter, I choose to cut a short section from a longer section I had of rubber submersible rated hose (5/16 or 8mm ID).
I could probably have used one of the straight section of corrugated hose instead, but I felt more comfortable that the filter could flex / move a bit easier mounted with thick rubber hose at its lower end (hose section from top of pump to filter).
John (Montreal, CANADA)
sailor is offline
post #18 of 21 Old Nov 30th, 2018, 10:18 pm
I think I ordered it from Amazon but the seller was EME.
The non corrugated length is 3 inches on either side leaving plenty for the short piece off one end. This is what I have left so enough to do it again if I need to.
Voyager likes this.
Gordon
Sugar Hill, GA
post #19 of 21 Old Dec 1st, 2018, 8:35 am
I had my fuel lines and filter replaced in my tank at about 100K after the line broke and I coasted to the gas station parking lot. I highly recommend to get these replaced at around 100K. I was in the dealership getting a service and asked about replacing the fuel filter and hey said they really don't like to do that because of the problems with removing the filter and upsetting the connections and the lines. I said ok. A week later, the line broke.
This replacing the in-tank components should be a recommended service at around 100K- preventative maintenance.
bmwcoolk1200 likes this.
Gdrdocbmw is offline
post #20 of 21 Old Dec 1st, 2018, 4:49 pm
I would not wait even close to 100K miles (or were you talking kilometers?). My u-hose failed at just over 50,000 miles and 6 years of age. Probably the last a 3 years of that had been in E10 fuel which I suspect is a big part of the early failures. Maybe if you could run pure gas, 100K would be attainable.
post #21 of 21 Old Dec 1st, 2018, 7:42 pm
I changed out my hoses @ 91,000 and kept the old ones as a spare since they still looked very good. Almost always run Shell (pumps all say, "may contain up to 10% ethanol") gas unless its not available (on trips).
Fuel Line in Tank 2005 K1200LT deputy5211 K1200LT 12 Sep 9th, 2012 9:39 am
Fuel Line Replacement Ride2Ski K1200LT 13 Apr 14th, 2012 11:42 am
Fuel Tank Vent Line question mowoc K1200LT 5 Jun 30th, 2009 11:08 pm
Fuel Injector cleaning-on the bike PhillWard Australia, New Zealand, and AsiaPac 4 Nov 28th, 2008 12:02 pm
Fuel Tank (non)Venting Issues browad K1200LT 11 Sep 16th, 2008 12:32 pm
