A Cd Problem On 05 Lt - BMW Luxury Touring Community
post #1 of 4 Old Sep 23rd, 2006, 3:19 pm Thread Starter
I JUST START TO RIDE MY NEW 05 LT END I HAVE THIS PROBLEM UFTER I LESTEN TO THE CD 30 MINOTS HE STOP END JUMP OTOMATIK TO RADIO ALOWEN THEN I NEED TO SHUT OFF END RSTART AGAIN THE SISTEM ENY BUDY NOW ABAUT IT SOMTHING?
zgmpl is offline
post #2 of 4 Old Sep 23rd, 2006, 3:55 pm
®win's Avatar
Yep had the same issue, only it happened at different occasions, different conditions. While playing a cd in the changer the audio suddenly changes to the fixed cd in the radio unit. Cd changer keeps playing, can't go back to changer using the buttons (radio doesn't know the changer) unless I shut down the radio completely and turn it on again. They've swapped the cd changer 3 times, cleaned all connectors between radio and cd changer just as many times. Finally, after 2˝ weeks of testing at the importer, BMW decided to swap the radio and the main radio harness. Problem is now solved, about a month and a half before I run out of warranty.
Erwin
R1200GS Adventure LC 2018, Blackstorm/Schieferdunkel Matt/Achatgrau (Triple Black), in full options, BMW Navigator V
R1200GSA LC '18 <- R1200GSA LC '14 <- K1600GTL '12 <- R1200GS Adventure '09 <- K1200GT '07 <- K1200LT '05 <- K1200LT '99 <- K1100LT '95 <- K75RT '92
®win is offline
post #3 of 4 Old Sep 23rd, 2006, 4:58 pm Thread Starter
Yes Its The Same
Exectly In My Bike I Will Tolk With Them Tanks Zeev
zgmpl is offline
post #4 of 4 Old Sep 24th, 2006, 3:11 am
If the radio looses the connection to the CD changer then it will do what you described. That could be from a bad wiring harness or loose connection, or from a fault inside the main radio.
Make your dealer replace whatever they need to get it working right.
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 12:17 pm
Rain induced problem on '04 LT? bwdjr K1200LT 3 Nov 19th, 2009 12:01 pm
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 11:37 pm
Oil Usage Problem Solved..Finally herk402 K1200LT 7 Sep 26th, 2006 1:51 pm
