Radiator fan problem - BMW Luxury Touring Community
post #1 of 4 Old Sep 22nd, 2006, 9:46 pm Thread Starter
Normally on my '02 LT (and on the previous LT, a '99) when the radiator temp rose to near the top of the scale (stop-and-go riding), the fans would come on, run until the temp dropped to just above the 1/2 way tick mark, and then shut off. This cycle would then repeat if I was still in stop-and-go traffic.
Now in stop-and-go traffic the temp rises, the fans both come on, and run for only 10 seconds, then shut off. Mebbe 30 seconds later the fans will turn on again, run for mebbe 30 seconds this time, and shut off. In neither case does the temp drop to anywhere near the 1/2 way tick mark - it drops a little bit when the fans run for 30 seconds, but not much.
Anyone else ever see this? Under extended Pinnacle warranty - going into the dealer next week for diagnosis and (hopefully) repair. I'll let y'all know what happens then.
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #2 of 4 Old Sep 23rd, 2006, 2:18 pm
ibbones's Avatar
Originally Posted by bob_menton
Normally on my '02 LT (and on the previous LT, a '99) when the radiator temp rose to near the top of the scale (stop-and-go riding), the fans would come on, run until the temp dropped to just above the 1/2 way tick mark, and then shut off. This cycle would then repeat if I was still in stop-and-go traffic. Bob
I have an 02 and mine come on like yours also. Drops to about the half way mark and then cuts off. I have not experienced the on/off thing.
"BONES" <///><
2018 R1200RT
2002 K1200LTC--- Belle
ibbones is offline
post #3 of 4 Old Sep 28th, 2006, 8:41 pm Thread Starter
Well, I got the bike back from the dealer today. It wouldn't misbehave while the dealer checked it out. Fans turned on at 221 deg. F coolant temp, turned off at 210 deg. F, back on at 221 deg. F, etc .....
Prior to this past spring, when I let the bike idle in my driveway until both fans turned on (and noticed how quickly they turned off), my cooling fans may not have operated for years. As you probably know, as long as you're moving, flow of air thru the radiators is sufficient to control coolant temp without the fans running. My kind of riding is such that I rarely get in stop-and-go traffic.
Sooooo ........... from now on, I shall occasionally let the bike idle in the driveway and cycle the cooling fan function. "Use it or lose it" may be the cure for this problem.
- Bob
Cowboy Bob Menton
Greenville SC USA
post #4 of 4 Old Sep 29th, 2006, 7:47 am
mneblett's Avatar
Bob, did your dealer take the bike out on the road, or just let it sit and idle up to fan temp? I'm wondering whether the problem is a flakey/failing fan relay -- if the coil is barely holding the contacts closed, road vibration could be sufficient to cause the contacts to open -- something that wouldn't be detected sitting in a service bay. Although its a pita to get to the under-tank electrical box, you might want to exchange the relay with one of the others in the box to see whether the problem clears. (Of course, all the above assumes you've already checked that the problem isn't a physical problem with the wires that control the relay).
Mark Neblett
Fairfax, VA
mneblett is offline
Radio Problem fixed thanks to the HoW... lhamonic K1200LT 8 Oct 20th, 2016 12:30 pm
Sputtering problem speedy K1200LT 22 Nov 20th, 2009 12:17 pm
Rain induced problem on '04 LT? bwdjr K1200LT 3 Nov 19th, 2009 12:01 pm
Weird electrical problem ronbok K1200LT 5 Jul 2nd, 2008 11:37 pm
Battery problem or what else johnkeyes K1200LT 2 Feb 13th, 2006 8:14 pm
