canisters rubber rubbing and cords - BMW Luxury Touring Community
post #1 of 2 Old Sep 22nd, 2006, 7:57 pm Thread Starter
alanforn's Avatar
Finally performed canisterectomy, was tempted to cut open. Can anyone explain in laymans term how this thing works? My take is vacuum is introduced via throttle body nipples, any gas introduced in vent is drawn through charcoal and trapped.Overwhelming flow is bypassed thru rear exit hose? Having to do something I blew thru the gas vent, felt some resistance, burbling noise and then clear. I'm assuming there was some fuel in the hose.
Also changing the rear Metz, noticed some rubber on swingarm. Suspect left over from trip to Curve Cowboy,(2 up, loaded and sustained 85mph). Something I should worry about? I am considering trying the Bridgestone rear, I have Metz front which is almost new. The BMW tech said radials are specified up to 2005?, after that bias are spec. Is it O.K. to run the rear radial with the Metz 880 front. I'm wondering what change occurred after 05 that changed the spec. I ultimately would like to try the Avon front/Bridgestone rear that many seem to prefer. I'm interested in better traction/handling than hi mileage. BTW- I saw a scary looking pile of old tires at Curve Cowboy, major cords showing on a few.
alanforn is offline
post #2 of 2 Old Sep 23rd, 2006, 12:02 am
Some people and most dealers go crazy with the thought of mixing tire brands and more so mixing bias/radials. I have tried many different combos and I like the Avon front(radial) and bias bridgestone rear. I have not heard of a good reason why they changed tires in 05. I can only reason that It is a better suited tire for the heavy LT. Bridgestone of course doesn't want to drop one its tires that it has paid for R&D and tooling costs. Just my wild guess...
Take a close look at the sidewalls from time to time looking for wear from the swingarm, You shouldn't see any.
Brian Ley
WA State of mindless sheep
2007 K1200GT
2010 650GS
BMWOA 119892
sanjaun2 is offline
