First oil leak. Metal in rear diff - BMW Luxury Touring Community
 2Likes
  • 1 Post By bmwcoolk1200
  • 1 Post By Why aint we riding
post #1 of 17 Old Feb 1st, 2016, 12:27 pm Thread Starter
bmwriderm's Avatar
Y2k just ready to roll over 90k miles. I've had for 9yrs and 70k miles with no real issue. Have been watching the rear diff as at the beginning of last season I found some bearing material for the 1st time. I took it To Austin Tx and to the Smokies last summer and have no noise or play in diff yet. But do think something is going on in there as have found some more metal. Warm temps in Indiana yesterday so I was going to fire it up for a ride and found a puddle of oil under it. Oil appears to be coming out where engine case extension bolts to trans. Clutch is not slipping. Sounds like I may be doing my 1st big tear down. May be interested in sending my diff to someone with the knowledge to do the rebuild for me or would buy a known good one if somebody has one. Thanks Bernie
bmwriderm is offline
post #2 of 17 Old Feb 1st, 2016, 12:59 pm
hallzee's Avatar
Re: First oil leak. Metal in rear diff
Sounds like a rear main seal; a common issue on the older LTs. This is a major tear down, but there is a LOT of good information (detailed directions, and even parts lists) here on the site.
Will need to do the clutch, since you have most likely contaminated it with oil. When I did my rear main seal, I also replaced the clutch slave, since I was in there.
I have attached a great document put together by Kenny Crawford (BlauBeeMr). He used the information he learned on this site, to compile into a single source.
File Type: pdf Changing a Main Seal and Clutch Slave Cylinder Guide K1200LT.pdf (3.87 MB, 357 views)
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #3 of 17 Old Feb 1st, 2016, 1:04 pm
Scouter-50's Avatar
Saddleman is the go-to man for final drive repairs.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #4 of 17 Old Feb 1st, 2016, 1:06 pm
bmwcoolk1200's Avatar
Bernie, Check with Saddleman on the FD rebuild.
On the other oil issue, it does sound like you are experiencing the dreaded O-ring failure. Just did it myself. It is an exercise in patience and documentation. A lift and a couple spare hands will make things easier. At 90K, I would be expecting to replace all 4 clutch parts. Friction disk, diaphragm spring, clutch plate and clutch cover plus any seals you care to do along the way with that Viton O-ring.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #5 of 17 Old Feb 1st, 2016, 2:04 pm Thread Starter
bmwriderm's Avatar
Thanks for the replies. I will be doing this myself. I done a lot of automotive rear diffs but think I may let Saddleman do this when I get the ambition to tear it a part.
post #6 of 17 Old Feb 1st, 2016, 3:25 pm
beech's Avatar
It is pretty amazing how many folks older K bikes are all showing rear main (O-ring) failure this winter. Here is a thread with lots of good information on the job ahead of you. Be prepared for lots of little things, crank case vent hose, intake seals, rear pivot bearings, transmission seals all around you name it.
Send me your address and I'll send you a 19x4 Viton oring, the problem item (free). Think long and hard about changing the main crank seal, a judgement call.
GregRS's journey into seal territory - I-BMW.com
Beech
beech is offline
post #7 of 17 Old Feb 1st, 2016, 3:50 pm
Beech, I should just send you my spare O-rings and let you hand them out. I bought a bag of 10 and used only the one.
Gordon
Sugar Hill, GA
post #8 of 17 Old Feb 1st, 2016, 6:07 pm
A puddle of oil is not always going to cause a clutch to slip. When the o-ring goes hard and cracks it is almost a guarantee the clutch is going as it dumps oil inside the clutch basket. But a rear main leak dumps oil outside the clutch basket. Unless the housing fills up with oil the clutch is relatively safe. Given the age and mileage I believe you are looking at a clutch job.
post #9 of 17 Old Feb 2nd, 2016, 11:08 am
deanwoolsey's Avatar
Out of curiosity, are you running synthetic motor oil?
deanwoolsey is offline
post #10 of 17 Old Feb 2nd, 2016, 1:58 pm
I will have one very soon. Will be installing a trike kit on my 2009 LT and will not need the diff. Cecil at (318) 541-3257
k5lo is offline
post #11 of 17 Old Feb 2nd, 2016, 2:35 pm
a 2009 FD doesn't have the hole for the speed sensor. I think he mentioned he had a Y2K.
Gordon
Sugar Hill, GA
post #12 of 17 Old Feb 2nd, 2016, 3:55 pm Thread Starter
bmwriderm's Avatar
No. I used The BMW oil and then switched to Lucas 20w50 traditional
post #13 of 17 Old Feb 2nd, 2016, 4:05 pm Thread Starter
bmwriderm's Avatar
Well I Emailed my local dealer and he said $2k to do clutch and rear main with slave cylinder. I did not tell them about possible diff issues. I just don't know if I want to spend this much time on the floor doing this repair myself. I'm still very happy with this bike and was planning on keeping it for a while but it is 16yrs old.
post #14 of 17 Old Feb 2nd, 2016, 9:58 pm
hallzee's Avatar
That's actually why I got rid of my '01, for my GTL. When I got rid of the '01, it was 13 years old. Parts in stock (at my) dealer were starting to be an issue, and I knew with an old discontinued bike, it was only going to become harder...
Anyway - that's how I reasoned it all in my mind after test driving the GTL.
Brian
MOA #136148
hallzee is offline
post #15 of 17 Old Feb 3rd, 2016, 4:40 pm Thread Starter
bmwriderm's Avatar
So I was looking at that seal set up. It appears that o ring failure at flywheel is more then likely caused by the rear main seal starting to leak. Am I right in thinking that the o ring is just kind of a secondary seal for the rear main. Where I'm getting here is this leak may seem bad at first because of the oil built up between the seals and since it does not effect the clutch at least not yet. Since I'm dealing with an old bike with the only real value being to me why don't I just try some engine stop leak that's kind of made for rear main seal leaks and ride on for now.
post #16 of 17 Old Feb 3rd, 2016, 6:02 pm
They are two totally separate seals. The main seal is Teflon and is a rotational seal between the block and the clutch basket. The O-ring is a stationary seal that only seals between the clutch basket and the shaft. There is no movement between the clutch basket and the shaft. The O-ring is compressed and it expands to fill the space and prevent oil from seeping through between the shaft and the clutch basket. When it gets hard and cracks, the seal there is compromised.
bmwriderm likes this.
Gordon
Sugar Hill, GA
post #17 of 17 Old Feb 10th, 2016, 11:29 am
Why aint we riding's Avatar
Off Topic but please share the trike conversion in another thread when its convenient. I am looking for something for my girl to ride and am hesitant to put her on two wheels. We have considered a Can Am but have some concerns there. An LT trike might fit the bill. Steve
bmwcoolk1200 likes this.
Why aint we riding is offline
oil pan leak ebear695 K1200LT 4 Dec 21st, 2012 11:02 pm
Oil leak and break lines brselman RT Series 7 Feb 27th, 2011 9:38 pm
Oil Leak on 2010 RT Lawrence_D RT Series 27 Jun 15th, 2010 7:50 pm
$65 oil is coming (maybe) RTTommy Chit Chat 17 Oct 10th, 2008 8:43 am
rear drive oil leak? louatlvc K1200LT 4 Jun 11th, 2006 7:17 pm
