ABS PUMP Dilemma - BMW Luxury Touring Community
 2Likes
  • 1 Post By davedionne
post #1 of 7 Old Jan 30th, 2016, 6:22 pm Thread Starter
ABS PUMP Dilemma
Greetings,
I have a 2000 K1200 LT... love it but the two red ABS indicators on the control panel have been blinking at me for a year.
San Diego BMW says it costs around $2k to fix, and I don't ride much anymore. Thinking of selling the beast,,, it only has 38k miles in 15 years,, always garaged and on trickle charger.
JCADELGADO is offline
post #2 of 7 Old Feb 2nd, 2016, 3:10 pm
Re: ABS PUMP Dilemma
I also have a 2000 Lt, and several years ago, I had the same issue. There are several things you can do to try to correct the problem short of replacing the ABS unit. First and foremost is the battery. If your battery is old and weak, even if you keep it on a Battery Tender all the time, it will cause an ABS fault. So one of the first things to do is check the battery. Secondly, when is the last time you flushed the brake fluids? I believe for the pre 2004 LT's, they recommend the fluids be flushed annually. Even if you don't ride much, the brake fluid gets very dirty and will absorb moisture and other contaminants. Third, you need to make sure there is sufficient brake fluid in the reservoirs, including the rear one. There is a rear reservoir on the right side sort of underneath the seat. Also, make sure the ABS sensors have the correct gap and are clean. The 2000 LT system will not reset itself, and therefore once you do these things, you will need to either find someone with a GS 911 to reset the defaults, or you will need to take it to a dealer and have them run it to clear the faults.
On my bike, all of these things did not correct the problem. I was lucky enough to find a used ABS unit on Ebay for $400, and a friend of mine and I changed it out one weekend. It has worked perfect since.
A couple of other points. The pre 2004 LT's are not servo assist systems, and they are much less complicated to work on. I am told there are a few places that can rebuild these units. I am not aware of any places that successfully rebuild the Servo units in the newer LT's. The good news it that unlike the Servo system in the newer LT's, the braking system still works great with the ABS pump not working. You just won't have anti lock brakes that are functional. If your ABS goes out on the Servo units, it isn't safe to ride the bike until it is fixed, or bypassed. Good luck.
jrlakin is offline
post #3 of 7 Old Feb 2nd, 2016, 3:45 pm
bmwcoolk1200's Avatar
If you are thinking of selling it because of the ABS issue, keep it and keep riding it. Pre 2002 US will not degrade the brakes for an ABS fault.
If you are wanting to sell it and get the issue fixed, in order to sell it, it would be good if you can get someone with a GS911 to hook up to it and get the error code. It could be as simple as one of the ABS sensors is bad and not the ABS unit itself. The bike has to sense forward motion on the sensors in order to clear the flashing lights from an initial start up.
See if you can isolate the issue so you know what you are dealing with. It may not be the expensive part.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #4 of 7 Old Feb 2nd, 2016, 5:43 pm
beech's Avatar
Yes, can be things like a wire to the abs sensor chaffed. But, all good suggestions above. And, if none of that works call
ModuleMaster
and see if they can fix it for you. They have been doing some BMW bike repairs. With those flashing lights and a bike that old, the retail price is rather low. I suggest fixing it and try to ride more.
Beech
beech is offline
post #5 of 7 Old Feb 2nd, 2016, 8:03 pm
johnbaker15's Avatar
Originally Posted by JCADELGADO View Post
Greetings,
The dealer is not doing you any favors at $2K, did they run any tests?
Module master can repair your unit for less than $500.00.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #6 of 7 Old Feb 7th, 2016, 6:52 pm
davedionne's Avatar
I just took my ABS Module out several weeks ago. Tried resetting it several times with my GS-911. Alternate flashing lights would return several miles later. GS-911 gave me an Piston fault code #16.
Decided to remove it and send it to Module Masters. Cost $350 plus shipping. 5 year warranty. Why buy something used or from ebay, not knowing its history or true condition.
It is just labor intensive to remove the module. Have to take off Upper Tupperware, Seats, Rear and Left side compartments. Not hard, just time.
I will be getting it back early this week and will let you know how it works out.
Buffalo, NY
beech likes this.
Dave Dionne
2000 BMW K1200LT: "Ghost Rider"
BMWMOA Member
LT - Buffalo Fire Dept.
Buffalo, NY
davedionne is offline
post #7 of 7 Old Feb 24th, 2016, 7:33 pm
davedionne's Avatar
Update.... Installed and working! Received the Module back, included was a note stating the the motor brushes were replaced. Took me longer to re-install. Did some needed maintenance, oil change, antifreeze, Transmission oil and Final Drive oil change.
Bled ABS Module and all brake calipers. Replaced valve cover gasket. Nothing hard, just time consuming. So if you are having ABS problems, check out Module Masters.
Patric likes this.
Dave Dionne
BMWMOA Member
Buffalo, NY
2006 LT ABS and Fuel Pump Fuse Hilton K1200LT 5 Feb 11th, 2014 9:55 pm
My Father purchased 2002 K1200LT with 7000 miles the abs pump stays on all the time Autodeal1 K1200LT 6 May 2nd, 2012 6:02 am
ABS pump not starting - rear only dslempke K1200LT 6 Dec 5th, 2009 9:34 am
03 LT ABS Pump turns on for no reason jroth3 K1200LT 12 May 10th, 2009 6:41 am
