Anyone try this trunk latch replacement? - BMW Luxury Touring Community
post #1 of 23 Old Sep 21st, 2006, 7:47 pm Thread Starter
http://www.simple-coffee.com/bmwparts/
The site states the following:
Solid aluminum replacement latch kit for the BMW k1200LT. Will not break like the original.
1. Kit includes; Solid Aluminum Latch, black powder coated (as original is)
2. 5 rivets with washers (1 extra provided just in case)
3. 3 press-in threaded inserts with stainless steel screws
4. Latch rod with 2 screws to replace latch rod that is destroyed in replacement procedure.
5. Directions with pictures.
$200 + shipping and handling
I broke my latch about a month ago and it will not work at all. Maybe I'll try this option. Appears to be well made.
Nathan
2000 K1200LT 81K miles
nswenson is offline
post #2 of 23 Old Sep 21st, 2006, 8:33 pm
I haven't bought one yet but it looks great. If you search for trunk latch you'll find a lot of coverage on the two different kits currently available.
mjordans2000 is offline
post #3 of 23 Old Sep 21st, 2006, 10:12 pm
Motomadman's Avatar
Waited for many months for BMWRIDER79 to finish this product. Finally wife ordered one from Millenhause for my birthday last June. What a surprise, that sneaky wench. Great product, easy install, grat instructions. Great improvement on the stock handle. Might be worth the extra bucks over the one your looking at. Can't say due to the fact I haven't seen this one. Hope someone gets one soon and gives us a review.......
Craig Hutchison
02 Pac Blue (Aka Blue Ox)
34° 14’ 12.63 N
119° 01’ 21.64 W
Why coast through Life when you can Corner it.
Motomadman is offline
post #4 of 23 Old Sep 21st, 2006, 11:24 pm
SilverBuffalo's Avatar
If you do a small modification on the stock one it doesn't break either
This statement is something I completely disagree with the entire latch mechanism can be removed intact by simply drilling out the rivits, I know because I just did this last week
Hans
St. Petersburg FL
2002 K1200LTE
"Silver Buffalo" Totaled 5/06
2005 LT
"Esperanza"
BushtecGenesisTrailer
SilverBuffalo is offline
post #5 of 23 Old Sep 21st, 2006, 11:34 pm
Florian's Avatar
Enlighten us...I thought they all eventually met their demise...how can I avoid it.
F
Florian is offline
post #6 of 23 Old Sep 22nd, 2006, 2:55 pm
You're right! The entire latch assembly can be removed from the bike just by drilling out the 7 rivets. However, we found that getting it all back together with rivets can be a bit of a challenge. It's doable - but not something we thought everyone could pull off. That's why our kit has CNCd inserts and stainless bolts to re-mount the latch assembly. Getting the business end of a standard riveter into the channel that holds the top case hooks - that's a trick, unless you've a 'long nose' riveter. We thought that might not be something everyone would have handy.
However, replacing the handle while keeping all the rest of the parts - that takes a new 'latch bar'. Only way to get the parts off the old handle is to drill out the peened ends of the latch bar goes between the handle's latching hooks.
That's from our installation instructins http://millenhaus.com/docs/install.pdf - page 8.
Millenhaus is offline
post #7 of 23 Old Sep 22nd, 2006, 5:25 pm
No disrespect intended,
you've obviously put a lot of thought, time and work into your product all for a reasonable price.
Those have to be the most detailed instructions I've ever read on anything.
But then I already knew how to drink a glass of water Hey I'm just kidding.
After reading everything now I understand your statement,
it's not just about removing the old one,
I really hadn't given a lot of thought to the re-install
Therefore I stand corrected.
Hans
St. Petersburg FL
2002 K1200LTE
2005 LT
"Esperanza"
post #8 of 23 Old Sep 22nd, 2006, 5:49 pm
Motomadman's Avatar
Did all the mods to the latch and it still broke. Less hassle if you just up-grade to one of the billet handles......My 2 cents....
Craig Hutchison
34° 14’ 12.63 N
119° 01’ 21.64 W
post #9 of 23 Old Sep 22nd, 2006, 7:31 pm
None taken or even suspected, Hans. No worries.
I was wondering who'd be first to comment on the 'how to drink water' bit Thanks for the comments on the instructions too. Idea was to make it as stress free and easy to do as possible. It isn't everyone's cup of tea to go swapping parts out of their LT.
But, to be clear - the original post was asking about a different product than ours. I'm 'the other guy'
post #10 of 23 Old Sep 23rd, 2006, 10:07 am
Lynn_Keen's Avatar
F
After the latch handle on my '99 broke and the entire lower 1/2 of the box was replaced under warranty, big bucks, I wanted to do what I could to prevent it from re-occurring. since it seems that it's always the left side that breaks I decided to simply remove the dowel pin in the lid from the top half of the latch. That leaves only the right side to keep the box closed but in over 100,000 miles between two Lt's it's never been a problem. It's not a very elegant fix but it is simple, effective, and more importantly-it's cheap!!
Lynn Keen
North East Florida
MSF #28271 Retired
'01 R1150 GS- totaled
'02 R1150 GS sold
'85 K100/EML sidecar sold
Lynn_Keen is online now
post #11 of 23 Old Sep 23rd, 2006, 10:16 am
The right hand side of my handle has broken. The dealer has ordered the lower half of the top case under warranty. I too have removed the pin on the broken (right) side of the latch.
“Res ipsa loquitur, sed quid in infernos dicet?”
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #12 of 23 Old Jul 18th, 2007, 4:00 pm
I found this post when i did a search on trunk latch. I have a 2002 K1200LT and the corner broke off the top exterior lever latch (where you stick the key) when i was closing the trunk. Sounds like you might have a solution. Please reply to [email protected]
Thanks!
VernRuth is offline
post #13 of 23 Old Jul 19th, 2007, 12:00 am
bmwrider79's Avatar
Latch kits
I am still selling them price is up to $225.00 shipping included 48 states only AK & HI and the rest of the world is extra.
My web site is dead and responsible for many lost sales. And do you want to pay a extra $75 for a kit just so I can have a web site?
2 choices clear coated with a brushed aluminum finish or black like OEM
1-1/2 to 2 hour install no special tools just basic tools most people have.
Solid aluminum billet construction
Easy to follow directions with pictures.
Money back refund minus pal pal charges and shipping if not satisfied.
If you want pictures send a PM with your personal email address.
I will reply with my phone number and business info and how to order.
Will have 10 ready by end of month. 4 are spoken for already.
Mike G
Northen Illinois Packer Fan
K1200lt 2002
LT Trunk Latch Maker
bmwrider79 is offline
post #14 of 23 Old Sep 29th, 2009, 10:32 am
Re: Anyone try this trunk latch replacement?
Do you still manufacture trunk latch replacement for K1200LT? I have a 2001 LT with a broken latch.
419-886-5211
[email protected]
Sixtyisgood is offline
post #15 of 23 Old Sep 29th, 2009, 11:36 am
hognot's Avatar
Ditto! I think mine is starting to go also!
hognot is offline
post #16 of 23 Old Sep 29th, 2009, 3:17 pm
Flyboy53's Avatar
My '99 came with a broken latch, so I'm in line too....
Back in the game-
'99 K1200LT Basalt Grey - New to me in '09
These are long gone:
'84 Honda CB700 Nighthawk
'82 Honda Goldwing Aspencade
'76 Goldwing
'71 Honda CB750
'70 Honda CB 350
'67 Honda CB 160
And a bunch of dirt bikes and dual sports
Flyboy53 is offline
post #17 of 23 Old Sep 29th, 2009, 4:58 pm
Busajets's Avatar
Let me know as well if there are any left.
Todd
96 percenter Still.
Busajets is offline
post #18 of 23 Old Sep 29th, 2009, 8:10 pm
kevincook's Avatar
Guys,
Check here: http://www.lttrunklatch.com/
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #19 of 23 Old Sep 29th, 2009, 9:33 pm
[QUOTE=kevincook]Guys,
Kevin[/QUOTE
If your's hasn't broke yet. These folks have a great " fix it before it breaks" kit.
roblee55 is offline
post #20 of 23 Old Jul 26th, 2014, 2:28 pm
Bigbux98's Avatar
Re: Latch kits
Do you still have any of the latches for sale? I know your post is old, but just seeing where I have to look for a latch.
Bigbux98 is offline
post #21 of 23 Old Jul 26th, 2014, 5:12 pm
Re: Latch kits
This is the guy you need to contact post #6 . Very high quality product.
post #22 of 23 Old Mar 6th, 2018, 6:25 pm
hi silver buffalo where can i get that bilet aluminium latch for my 2005 k1200lt?
beemermam is offline
post #23 of 23 Old Mar 6th, 2018, 9:42 pm
Axle's Avatar
you really should read all the post/s, the business referred to in this thread and the other one you queried the same thing in has closed, you need to fix it yourself get a s/h one or buy a new top case from bmw. I hope you get it sorted.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
trunk latch broken on 02 LT d8ug K1200LT 2 Aug 1st, 2008 7:41 pm
Trunk latch replacement kit - almost ready Zotter K1200LT 24 Jul 5th, 2008 5:41 am
Trunk Latch: Bad - Good - Bad - Solution ytk K1200LT 17 Nov 19th, 2007 12:09 am
Good News: Trunk Latch & Plugup ytk K1200LT 6 Aug 15th, 2006 6:36 am
