Hydraulic stand aand abs flashing - BMW Luxury Touring Community
 5Likes
  • 2 Post By Whiskey
  • 2 Post By Chayside
  • 1 Post By want2tour
post #1 of 13 Old Jan 26th, 2016, 4:21 am Thread Starter
Hi there, This community has saved me many times for which I am grateful. This morning my 1200lt was reluctant to start but eventually did, I rode it for about 10 miles and went to put it on stand, the hydraulic stand indicator light was flashing furiously and the stand wasn't working, then the abs warning lights started to flash, hence no asb brakes, any ideas??>?? Appreciation in advance, the abs modulator had been changed two years ago, so hopefully no reoccurance,
SlanePaul is offline
post #2 of 13 Old Jan 26th, 2016, 5:08 am
Whiskey's Avatar
Re: Hydraulic stand aand abs flashing
Battery? That could cause multiple seemingly unrelated failures or warning lights.
deputy5211 and JNW003 like this.
2000 R1100RT
Whiskey is offline
post #3 of 13 Old Jan 26th, 2016, 5:48 am
I agree.
Painterman is offline
post #4 of 13 Old Jan 26th, 2016, 9:06 am Thread Starter
Thanks all Ill check later and update, appreciated
post #5 of 13 Old Jan 26th, 2016, 3:05 pm Thread Starter
Hi all, just an update, battery when meter was on it read 13.1 going up to 14.3 with bike started. So I guess its not that. The abs light was flashing very quick. I disconnected battery, reconnected it, then manually pushed up the stand, needs a service anyway, as it retracts slowly, the abs light flashed normal, and had brakes, then the hydraulic stand started operating again. Not sure what I did to rectify it, or if it will stay working,
post #6 of 13 Old Jan 26th, 2016, 7:36 pm
Whiskey's Avatar
Bummer. I was hoping you'd find a bad battery. They ain't cheap per se, but cheaper and easier than most other things. Hopefully it stays working, but be cautious taking her very far for the next while.
2000 R1100RT
Whiskey is offline
post #7 of 13 Old Jan 26th, 2016, 8:29 pm
guitarjim's Avatar
How cold is it there? (How cold was it when you first started the bike?)
guitarjim is offline
post #8 of 13 Old Jan 27th, 2016, 12:45 am
Had same problem a while back, turned out to be the battery despite all things checking out voltage wise. But once load was on battery voltage dropped to nine volts. Multitude of problems were happening sometimes stat other times narder. Get battery load checked.
SlanePaul and johnbaker15 like this.
BMWMOA
Never ride faster than your Guardian Angel can fly
2007 K1200LT Storm Grey metallic
Uni Go Trailer
Chayside is offline
post #9 of 13 Old Jan 27th, 2016, 4:11 am Thread Starter
It was 9 degrees when it happened
post #10 of 13 Old Jan 27th, 2016, 7:17 am
johnbaker15's Avatar
What he said.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #11 of 13 Old Jan 27th, 2016, 12:19 pm
want2tour's Avatar
If you can find an analog volt meter, you could see what the battery drops down to during cranking. Can't do that with a digital meter.
beech likes this.
2005 KLT Graphite Gray
2003 F650GS Black
*Too slow for fast women
want2tour is offline
post #12 of 13 Old Jan 31st, 2016, 7:17 pm
Another vote for the battery. As they go bad then can maintain a full surface charge but draw down drastically under load. Imagine wiring nine AA batteries in series and trying to crank the bike with 'em.
Also at 9 degrees a failing battery can freeze. I think. Or I've been snookered by garage legends.
Urbanhermit is offline
post #13 of 13 Old Feb 1st, 2016, 10:03 am
biometrics's Avatar
Definitely have the battery load tested.
1983 R100 Airhead & Velorex 562 Sidecar
2000 K1200LT (SOLD! ...just too darn tall for me!)
1999 R1100RT-P (SOLD!)
1983 Honda Nighthawk 650 (SOLD!)
1973 Yamaha 125 Enduro (Ripped off!)
My Avatar? U.S. Army - Kagnew Station, Asmara, Eritrea, East Africa, 1972-1973
biometrics is offline
Intermittent flashing brake failure light Rob-K12LT K1200LT 7 Aug 1st, 2014 6:29 am
Flashing ABS lights (my turn) SilverBuffalo K1200LT 2 Apr 18th, 2014 4:23 pm
Kickstand light flashing ScottNSLT K1200LT 3 May 31st, 2013 7:39 pm
Flashing ABS lights. BMW_forever K1200LT 2 Sep 24th, 2012 9:20 am
Flashing head lights Ford1604 K1200LT 9 Dec 19th, 2008 6:42 pm
