Slight Knocking On My LT - BMW Luxury Touring Community
 1Likes
  • 1 Post By GaryEm
post #1 of 8 Old Jan 3rd, 2016, 11:06 am Thread Starter
Hi I've got a slight knocking from the suspension on light bumps ,what is the likely cause please?
Is there a special tool socket to remove the lower ball joint ?
bottom nuckle ball joint ?
steering damper rubber?
head bearings?
bike has done 36000 miles
Andrew
andrewb2015 is offline
post #2 of 8 Old Jan 3rd, 2016, 11:44 am
GaryEm's Avatar
Re: Slight Knocking On My LT
I would say it is your shock bottoms out I had that replaced the OEM with a new spring all is fine or you can buy a whole new shock
beech likes this.
Gary
2003 K1200LT
GaryEm is offline
post #3 of 8 Old Jan 3rd, 2016, 1:45 pm
want2tour's Avatar
head bearings?
Andrew
Are you sure it's coming from the front shock?
If it's bottoming out, have you tried reloading the hydraulic oil in your rear shock pre-loader? Very quick, very inexpensive, pretty effective. Saved me big bucks. Now happy enough with the ride. A new progressive spring or a new shock would be better, but for now, happy enough.
Disclaimer; I don't know what's going on with your shock or if you have another problem, but re-filling the hydraulic fluid is a good thing to rule out, costing under $10 and 20 min of your time. Can be done faster next time.
2005 KLT Graphite Gray
2003 F650GS Black
*Too slow for fast women
want2tour is offline
post #4 of 8 Old Jan 3rd, 2016, 3:16 pm Thread Starter
Hi
It's not bottoming out its on very light bumps small pot holes etc ?
post #5 of 8 Old Jan 3rd, 2016, 4:12 pm
Axle's Avatar
I would guess at that mileage it is none of those, but to what it is only you or a dealer can work it out, it could be anything from a loose front fender to a centrestand I had a rubber missing in my chrome exhaust cover when I hit a bump it rattled on the side stand so ,"it could be anything". Put it up on the centre stand and have a real good poke around you will find it eventually.
"bottom nuckle ball joint ?
head bearings?"
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #6 of 8 Old Jan 3rd, 2016, 4:15 pm
want2tour's Avatar
I think that the steering head bearings aren't a likely suspect. The miles on the bike don't suggest that. But you can put a jack under the oil pan area & elevate the front wheel, then turn the handlebars back & forth to feel for or listen for problems.
I think the Clymer manual may help with some diagnostics. If you don't have one, I can take a look at mine.
Also,have you grabbed your steering damper & given it a good shake to see if it has an issue?
All your tupperware fasteners tight? Hard to say where the knock is coming from at this point.
2003 F650GS Black
post #7 of 8 Old Jan 6th, 2016, 11:33 am
deanwoolsey's Avatar
Find yourself a good bump that makes it knock and then hit it with the front brake lightly applied. Could be the brake pads or possibly your steering damper.
deanwoolsey is offline
post #8 of 8 Old Jan 6th, 2016, 3:16 pm
Axle's Avatar
Also could be rotors they don't knock but rattle, but I spose it depends on what you are hearing
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
knocking sound--transmission related? hentmanmd GS Series 1 May 29th, 2012 8:00 pm
a slight smell of antifreeze bobst2 K1200LT 9 Feb 9th, 2011 11:28 pm
HELP - Knocking sound BigGeo K1200LT 21 Mar 31st, 2009 8:40 pm
Knocking sound -electrical problem? Smith K1200LT 4 Mar 30th, 2008 10:56 am
knocking noise in front over bumps? getting much worse dodgeman88 K1200LT 13 May 28th, 2006 6:07 pm
