2002 k1200lt ABS Pump - BMW Luxury Touring Community
post #1 of 5 Old Oct 31st, 2015, 8:25 pm Thread Starter
Took bike to dealer today. Was told ABS pump is needs replaced. $3000.0. Was thinking of selling bike anyway. Thinking about getting a used r1200gs. I was originally wanting to get $5000.0 for the LT. Bike has 55k miles and is in good shape. What should I ask for bike now? How hard would it be to pickup used Abs unit and install myself. Thanks for any help.
Sjgolden is offline
post #2 of 5 Old Oct 31st, 2015, 8:34 pm
johnbaker15's Avatar
Re: 2002 k1200lt ABS Pump
There was a ABS pump on ebay for around $500 last week.
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #3 of 5 Old Nov 1st, 2015, 6:49 am
For about $100 you can "by-pass" the ABS system, just completed it on my 2002.
Royal Hose and Brass - Matthews NC can make the 40" SS hose for you, couplers are $4 apiece, be sure to pull the relay while you have the tank off so the flashing lights are no longer active.
Also clamp the overflow hose for the fluid reservoir (front control circuit) so it does not drain down.
Great time to change air filter as well.
Regards,
Boots
IBA#50871
Come ride with me;
2006 R12GS 100K miles, current ride
1972 R60/5 Toaster 44K miles, current ride
2002 K12LTE 58K miles, SOLD
kedwards005 is offline
post #4 of 5 Old Nov 1st, 2015, 2:10 pm Thread Starter
Thanks that sounds like what I need to do. I need to get instructions on how to do this thanks for the reply. Makes me feel better.
Sjgolden is offline
post #5 of 5 Old Nov 2nd, 2015, 12:06 pm
ColoradoGrant's Avatar
Hi, I by passed mine as well, there are lots of write ups documenting how to do it. Obviously, I loved the power assisted ABS brakes, but not knowing if my brakes were going to fail really sucked! I have been happy knowing my hydraulic brakes will work every squeeze the same way...
Grant
Colorado Springs CO
ColoradoGrant is offline
Permantly Disable K1200LT ABS jsphillbiker K1200LT 25 Sep 7th, 2018 12:11 pm
Fuel pump issue on 2001 k1200LT Gizmoguy K1200LT 9 Aug 27th, 2014 1:28 pm
2006 LT ABS and Fuel Pump Fuse Hilton K1200LT 5 Feb 11th, 2014 10:55 pm
Is there a procedure here to remove the ABS pump on a 2000 K1200Lt roblee55 K1200LT 15 Jan 17th, 2014 8:52 pm
My Father purchased 2002 K1200LT with 7000 miles the abs pump stays on all the time Autodeal1 K1200LT 6 May 2nd, 2012 7:02 am
