Unable to open trunk - BMW Luxury Touring Community
post #1 of 5 Old Sep 11th, 2006, 2:12 am Thread Starter
Hello,
I have searched the forum, but could not find anything similar. I am not able to open top trunk on my 99LT. The latch moves about half way, then I it stops. I tried to move both the latch and the top of the trunk with quite a lot of force, but it didn't help :-) There is nothing visually wrong with the latch (no broken corners). I have some clothes in the trunk, so I do not know if that can somehow block it from opening.
Any ideas how to get it open?
David
Czecho is offline
post #2 of 5 Old Sep 11th, 2006, 2:37 am
Zotter's Avatar
Well, something is 'jamming' - obviously. If you can get an appropriate tool up behind the handle, grab both of the arms that come down from above (they're the ones that connect to the handle itself, where it often breaks on the upper corners) and pull - you should be able to get it open without damaging the latch.
Unless you want to replace the handle, do *not* attempt to force it open by using the handle! Get something else up in there to pull down on the arms. They should be able to take it - the handle certainly can't.
You may want to try pushing down on the trunk lid at the same time. If you've 'overfilled' it, you could just be increasing the friction on the latch hooks.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #3 of 5 Old Sep 11th, 2006, 8:36 am
There are a couple of "E" clips on pins internal to the mechanism. I had one pop off and I could not open the trunk. I rode around a bit and pressed down on the top of the trunk and it finally opened. Usually this causes one hook to not release. Try a little riding (to shake thing up) and attempt again. Then once it is opened, remove the trunk liner and inspect the mechanicals for a loose pin. Also look for the loose "E" clip. Good Luck.
post #4 of 5 Old Sep 12th, 2006, 7:10 am Thread Starter
Exactly as you said, jzeiler. I finally managed to open the trunk and one of the E clips was poped off as well as the pin itself. Driving around did not help though. I had to use magic spells and special movement coordination on the trunk to get it open :-)
Czecho is offline
post #5 of 5 Old Sep 12th, 2006, 8:07 am
Glad you were successful David. Make sure you squeeze the "E" clip a little to close it up if it is loose, don't want it to fall off again as those magic spells only work once.
Trunk Latch: Bad - Good - Bad - Solution ytk K1200LT 17 Nov 18th, 2007 11:09 pm
Good News: Trunk Latch & Plugup ytk K1200LT 6 Aug 15th, 2006 5:36 am
Trunk light problem jbuffalo K1200LT 1 Jun 3rd, 2006 2:12 pm
Top Trunk Skylark K1200LT 17 Jan 18th, 2006 12:42 pm
