What Triggers a Fault Code ? - BMW Luxury Touring Community
post #1 of 2 Old Sep 10th, 2006, 3:42 am Thread Starter
Miles of Smiles
Hilton's Avatar
Smile What Triggers a Fault Code ?
Been on holidays for almost 2 months. Had "Jenna" tucked up nice and sweet with new oil and both wheels off the ground. Set up the BMW gel battery charger to look after the sparks and all was well. Decided to pull the fuel pump fuse prior to starting up and turn the engine over for around 10 sec to push some oil around the galleries before actually starting. Replaced the fuse and she fired up straight away. Life is once again in balance.
Just wondered if the initial cranking without the fuse would create a modec memory "event" ie failure to start or such.
Also wondered if any one has a list of the various fault codes brought up during dealer services?
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #2 of 2 Old Sep 10th, 2006, 6:42 am
grifscoots's Avatar
I know that I've pulled #4 fuse on my 2000, while doing some work on her, to clear the memory, stuck said fuse in my pocket and forgotten about it. They don't start real good and you freak for awhile till you remember.
I don't think it throws any type of code.
-=grif=-
Grok
grifscoots is offline
Paint Code Help scott122262 K1200LT 3 Jul 26th, 2006 9:32 pm
ABS fault problem GBarnes K1200LT 6 May 5th, 2006 5:52 pm
New Un-Lock code for SPIII OKUIII GPS 2 Mar 19th, 2006 9:12 pm
LT down ABS fault mkiesel K1200LT 11 Feb 25th, 2006 11:18 am
Paint Code pavehawkfe K1200LT 2 Nov 27th, 2005 9:12 pm
