Clutch bleeding procedure - BMW Luxury Touring Community
post #1 of 5 Old Sep 8th, 2006, 10:26 pm Thread Starter
kevincook's Avatar
I did a search in the HOW and in the archives but can't find what I'm looking for.
I replaced the slave cylinder and need to bleed the clutch. I read the manual but was wondering if there were any shortcuts. Do I need to remove the handlebar trim and rotate the clutch resevoir? Only the germans would actually make you do something like this.
Is there a link to a more efficient procedure or is the manual as simple as it gets?
When I turn the handlebars to full right lock the resevoir looks pretty close to being level to me. How close does it need to be?
I need to pick up a bleed screw in the morning someplace. I missed that on my list of parts and tools.
Kevin
Slave Cylinder Procedure->
kevincook is offline
post #2 of 5 Old Sep 8th, 2006, 10:52 pm
You can get the speed bleeders from NAPA. I think I paid $11 or so for a pair. The procedure itself is pretty straight forward. If you install the bleeders, the fluid should gravity feed into the slave. You may have to get a positive displacement suction assist on the bleed side to draw the fluid and bubbles through, but should be no big deal to get an air-free system with a little patience.
Sofitel505 is offline
post #3 of 5 Old Sep 8th, 2006, 11:26 pm
http://www.speedbleeder.com/
These work great. The 99 LT is pretty simple. Here is the thread post from the past.
http://www.bmwlt.net/ubbthreads/show...&sb=5&o=0&vc=1
amsoilguy is offline
post #4 of 5 Old Sep 9th, 2006, 6:25 am
grifscoots's Avatar
A little heads up on speed bleeders, or any bleeder for that matter. If you're having problems bleeding, air is getting around the threads of the bleeder. Use a leetle teflon tape to seal them up.
Joel's write up on bleeding is good. I just turn the handlebars without locking and wrap a rag around the reservoir. Might lay an old towel on the body work, too.
-=grif=-
Grok
grifscoots is offline
post #5 of 5 Old Sep 9th, 2006, 1:27 pm
I don't rotate the master cylinder. You can get pretty close by just turning the handlebars. If you're picky, then park the bike on a slight slant (driveway entrance) to get the master cylinder a bit more level. But the big thing is to not let the fluid get low enough to draw in more air.
Bleeding Gearbox & Clutch ??? Frenchy K1200LT 15 May 1st, 2008 11:06 am
No Clutch! birdman K1200LT 8 Sep 6th, 2006 11:36 am
clutch test? shocks alanforn K1200LT 2 Jun 16th, 2006 5:51 pm
lost my clutch parishollow K1200LT 11 Jun 6th, 2006 7:45 am
