Torque setting on brake calipers ?? - BMW Luxury Touring Community
post #1 of 12 Old Sep 7th, 2006, 9:09 pm Thread Starter
Just received Motolights and want to install on 06 KLT this weekend. Does anyone know what the torque setting is for the brake caliper?
BToliver is offline
post #2 of 12 Old Sep 7th, 2006, 9:31 pm
Brake caliper to fork tube = 40 Newton Meters.
post #3 of 12 Old Sep 7th, 2006, 9:35 pm Thread Starter
Thanks, Dick, just what I needed.
BToliver is offline
post #4 of 12 Old Sep 8th, 2006, 12:24 pm
Shogun54's Avatar
Be careful! I used this torque setting and snapped two of the bolts before coming to my senses. My friendly BMW shop foreman informed me that they tighten these bolts ' till they are tight' and disregard the factory spec. YMMV, but I hope it works our better for you.
Brett
Get busy livin' or get busy dyin'!
2003 BMW K1200LTC "El Gato Grande"
1993 Suzuki GSXR1100W
1978 Suzuki GS1000C 'Project'
Shogun54 is offline
post #5 of 12 Old Sep 8th, 2006, 1:11 pm
That is only 29.4 ftlbs, and that is not a lot of torque. Sure you had the correct bolts? I'm sure David will chime in on the breaking strength of those bolts as all I could find is that the standard dry torque for a fine thread M8 ISA is 29.4 Ft Lbs
post #6 of 12 Old Sep 8th, 2006, 8:13 pm
(1) Typically the bolts don't break - rather, they start to strip the threads that they screw into when overtorqued. It's not uncommon to need Heli-Coils to replace the stripped threads.
(2) According to my dealer, the torque has changed from the first LTs (pre-power brakes) to the '02 and newer LTs (with power brakes). The newer LTs have a lower torque spec for these bolts than the older LTs had.
(3) And when the new, lower torque spec is used on the newer bikes, the service techs still see some occasional thread stripping.
I **think** the newer bikes are spec'd at 21 lb-ft torque for the brake caliper bolts. Please check with your dealer to be sure.
- Bob
Cowboy Bob Menton
Greenville SC USA
bob_menton is offline
post #7 of 12 Old Sep 8th, 2006, 9:51 pm
You are correct Bob, the 05 manual states 30 Nm or 22.1 Ft Lbs and that is for ALL year Integral Brakes. Only the older ABS II was spec'ed at 40 Nm.
post #8 of 12 Old Sep 8th, 2006, 10:52 pm
Shogun54's Avatar
Sorry guys, bolts were the same ones that came out of the mount. They both snapped, as in broke in half, about 1/4 inch up from the end of the threads. Had to get them out with a drill. 'New' bolts ( one actually new and the other dug out of the spare parts bin at the dealer...not a well stocked part ) worked very well when tightened as described above. Maybe I'm just lucky and got some defective bolts originally. Gives you a real good feeling doesn't it?
Brett
Shogun54 is offline
post #9 of 12 Old Sep 9th, 2006, 1:39 am
TomMoss's Avatar
Torque
'03 manual also says 30 Nm
2003 K1200LT Titan Silver - The Great Escape
TomMoss is offline
post #10 of 12 Old Sep 9th, 2006, 3:14 am
Miles of Smiles
Hilton's Avatar
Smile BMW versus Brembo
Seems from what I've read that if your calipers are branded " Brembo" then it's 40 Nm. If they are branded "BMW" then it's 30 Nm. Haven't broken any bolts yet. Not sure when the change over occured, or why there should be any difference on bolts doing the same job? Maybe there are some differences with the caliper. Cheers.
Jenna: Ocean Blue '06
Rena: The Committee.
ET4 Thing 1
ET4 Thing 2
Hilton is offline
post #11 of 12 Old Sep 9th, 2006, 5:50 am
Hi, Brad -
Geez - my apologies that I gave you bad info on the Nm setting for the caliper bolts when adding the Moto-Lites. As Hilton and Menton and others have said, my shop manual, in listing the 40 Nm torque value, applies only to the pre-'02 model years of LTs with Brembo calipers. I'll be sure and check the LT model year of future questioneers, and keep my trap shut if their LT isn't the same as Toad (my '99).
Hope you read the rest of the replies from the good folks with newer model LTs and shop manuals, and do the job correctly. Again, sorry for the incorrect #.
post #12 of 12 Old Sep 9th, 2006, 6:11 am Thread Starter
No problem...... After reading the post from Brett about "snapping two of his bolts" I decide to order the shop manual. Got the lights installed last night and would like to post a picture but can't figure out how to do it.
Thanks to the archives, I was able to mount and wire everything myself & donated the money I saved to the forum.... Thanks Guys!
_______________
Brad
06 KLT
Still have an Ultra Classic for sale
Tulsa, OK
BToliver is offline
Another Brake Problem and a Near Miss chuckle K1200LT 31 Mar 14th, 2016 11:56 am
Front Brake Pad R&R (looong story) was K1200LT 1 Sep 3rd, 2006 10:48 pm
Extended brake pedal, helps the use of the foot brake pozo_izquierdo K1200LT 1 Jul 30th, 2006 4:40 pm
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 10:37 am
Need some help with brake bleeding scott122262 K1200LT 13 Mar 20th, 2006 9:04 pm
