Help needed, radio died after washing - BMW Luxury Touring Community
post #1 of 5 Old Sep 2nd, 2006, 9:05 am
jswag13
Guest
Posts: n/a
Question Help needed, radio died after washing
I did a detailed washing about 2 weeks ago, and now my radio is dead. In addition, my MotoLights are also not functioning. I pulled the radio fuse, (block B, fuse 8) and read voltage on the hot terminal. The fuse tests good... Does anyone have any idea what I could check next to affect a repair?
post #2 of 5 Old Sep 2nd, 2006, 9:30 am
I would guess the radio problem is due to water leaking by the buttons on the control element (panel). If it hasn't dried out naturally you may have to pull the control element, open it, and clean and dry it with contact cleaner. The control element requires a T9 to open. Would hurt to apply dielectric grease to the connectors while you're in there.
Of course in order to remove the radio you must take off the side fairings, etc. Fortunately there are several great sets of instructions on how to do this here on this site. I don't have the link off hand but search on 'radio removal' or such should pop them up.
Motor On ,/'
jkersh1 is offline
post #3 of 5 Old Sep 2nd, 2006, 4:46 pm
jswag13
Guest
Posts: n/a
next step?
Well, I took the whole thing apart... Removed the plastic, pulled the stingray, opened up the radio, checked the 10amp fuse in the back of the radio, unplugged and cleaned all of the connections both in the front and in the back. I also left the battery unplugged for an hour and a half and tried to reset the unit that way. I still have power at the fuse under the passenger seat, but no lights whatsoever on the control panel. Absolutely nothing happens when I try and power on the unit.
If anyone has any possible suggestions for how to proceed from here, I'm a fairly desparate man and would be open to them! It's great to have this community as a resource. For now I think I'll take a break, as the last several hours have been frustrating to an extreme.
Thanks again for all your help, both past and present.
post #4 of 5 Old Sep 5th, 2006, 4:11 pm
jswag13
Guest
Posts: n/a
What to replace?
Can anyone that's had expereince with this type of problem let me know which item needs to be replaced? I'm not sure whether to buy a new head unit or a new control unit. After taking everything apart, there is absolutely nothing that shows any sign of water or even dampness. I notice that they are both fairly expensive, and for the life of me I can't figure out what's busted.
If I remember correctly, I think I got really stupid and sprayed water under the seat (with the seat up) in the battery compartment to get rid of some of the road dust in there. I'm guessing that was probably my downfall.
Also, if anyone has a radio or control unit for sale, I'm in the market to buy one.
thanks!
Jim
post #5 of 5 Old Sep 5th, 2006, 4:14 pm
jswag13
Guest
Posts: n/a
P.s.
The motolights work great if you hook up both the negative and the positive cables... Initially I thought the failures were related. Sorry if this confused the situation.
Radio just quit atps1234 K1200LT 62 May 29th, 2017 10:43 pm
Rained out radio LCD kip K1200LT 8 Jun 30th, 2006 11:12 am
Radio flickering KMC1 K1200LT 3 Jun 7th, 2006 10:50 pm
K75RT - radio & other bits needed ChrisJF Other K-Bikes Discussion 2 Mar 19th, 2006 5:30 am
