power commander - BMW Luxury Touring Community
post #1 of 8 Old Aug 29th, 2006, 12:49 pm Thread Starter
power commander
Called up San Jose BMW and they said they use the power commander coded for the k1200rs for the LT and the Remus. Has anyone done so ? CUrious to see what the outcome is\was.
ian
ihbond is offline
post #2 of 8 Old Aug 29th, 2006, 3:05 pm
I have one on an FJR1300 and it is worth every bit of $300. There is no reason I can think of why the RS version would not work on the LT. After all, its just a piggyback on top of the Motronic's fuel maps. As long as the new Bosch 5 wire O2 sensor threads into your exhaust, a custom tuning link map can be made from a dyno run. That way, its specific to your bike's config and the closed-loop ratio can be dialed in to suit on highway cruises. As long as San Jose has got the connector/wiring harness issues resolved, I'd say it's a no brainer to do it.
Sofitel505 is offline
post #3 of 8 Old Aug 29th, 2006, 7:18 pm Thread Starter
got a call
back from san jose BMW and they said it should all just plug in. Pretty cool!!!
ihbond is offline
post #4 of 8 Old Aug 30th, 2006, 1:08 pm
I would be interested to know how it turns out for you, please keep us posted!
Thanks!
I can't imagine getting the LT on to the dyno. I have dynoed a lot of bikes, and that sounds scary!
Mopos is offline
post #5 of 8 Old Aug 30th, 2006, 2:27 pm
i'm pretty sure everything from cams to compression ratios and fuel injectors are different between the LT and the RS. i would think that this might make ignition modules different, too.
KBandit is offline
post #6 of 8 Old Aug 30th, 2006, 3:51 pm
The RS/GT PCIII doesn't touch valve or ignition timing at all. Its nothing but an offset correction to the injector duty cycle. I've had the LT on a dyno and its no big deal as long as its strapped properly. Fun to be going 120 MPH standing still. All they do is put the O2 sniffer in the pipe, hold the throttle at 2, 5, 10, 20, 40, 60, 80, 100% open and the dyno loads the wheel to vary the RPM's all the way up at each throttle position. The tuninglink adjusts the fueling to dial right in at 13.1 or whatever Dynojet recommends for the K1200 motor. Then you can adjust the closed loop setting to let the O2 on the bike give you the best mileage at stoic (14.5). I think there is also an accelerator pump option to give it an extra shot of fuel right at throttle opening to further smooth things out especially in really cold weather.
post #7 of 8 Old Aug 30th, 2006, 4:07 pm
Talking
cool. i stand corrected. errrrr ... sit corrected.
KBandit is offline
post #8 of 8 Old Aug 30th, 2006, 9:12 pm
No prob. I had to actually watch them doing it to get it all straight in my head. To do it right, takes about 90-120 minutes on the dyno. Most of the time they have to run through the cycle twice to really dial it in.
iWay 500c audio problem was GPS 11 Apr 26th, 2007 8:07 pm
Just curious, any news on Power Commander emsweeney K1200LT 1 Feb 2nd, 2006 10:20 pm
Power Commander PCIII Update TX03LTC K1200LT 5 Nov 26th, 2005 4:28 pm
Bike power to the trailer for accessories Dezrae Australia, New Zealand, and AsiaPac 2 Oct 25th, 2005 4:43 am
power commander rtgrey K1200LT 2 Oct 1st, 2005 10:02 pm
