Power Outlet Question - BMW Luxury Touring Community
post #1 of 8 Old Aug 29th, 2006, 11:19 am Thread Starter
dwillie's Avatar
I was wondering if I should wire an outlet straight from the battery to run my heated clothing, or use the power outlet BMW provides. I believe the outlet down by the drivers left foot is rated at 15 amps, and this is shared with the radio and some other small things. I don't often wear all my heated clothes at once, but if I needed to, I'd like to be prepared. If the jacket is 77 watts, pants 45 watts, and gloves 22 watts.......that's about 144 watts total. In the event I need to run the items at full on, can this outlet handle it?
As an alternative, I thought about disconnecting the powered wire BMW sends to that outlet, protecting it from weather, abuse etc, and running a dedicated fused power wire down to that outlet straight from the battery. Any opinions and guidance is appreciated, thanks. d.
dwillie is offline
post #2 of 8 Old Aug 29th, 2006, 11:38 am
power outlet
I use the power out lets for the electric jacket -no problems
also i pug the battery tender in there
JBFST is offline
post #3 of 8 Old Aug 29th, 2006, 11:57 am
Hey, Don -
You prolly already know this, butt there is another available female socket on the right side of the bike, opposite of the left socket. The right side socket is zip-tied to the frame rail and just requires drilling out a hole in the lower fairing piece at the obvious vertical, flat molded site, and installing such as a Powerlet connector receptacle to fit the opening and secure it to the socket. I "think" it's ignition switched, so it's hot only when the ignition is on, like the pillion outlet on the trunk - better verify that if you go this route, tho. Might be some info on it in the HOW pages.
post #4 of 8 Old Aug 29th, 2006, 11:14 pm Thread Starter
dwillie's Avatar
Thanks for the information Dick. I did not know power was available on the left side too. I saw the flattened area where a plug would fit nicely, but didn't know power was already there. Thanks all for the suggestions, and the personal messages. d.
dwillie is offline
post #5 of 8 Old Aug 30th, 2006, 12:43 am
Watts = Amps X Volts. Assuming a nominal 12V, you're looking at 12 Amps. You're probably closer to 13V while running, which makes around 11 Amps. Either way, the stock output plug will handle that just fine.
Also, if you get a proper switching controller (HeatTroller for example) then it will draw only as much power as it needs to supply the heat you request. So turning it on halfway will use much less power than full on. They also make dual controllers that let you set different temps for jacket and pants, of jacket and gloves, etc.
These controllers can be plugged in to a standard BMW Powerlet socket, or hard wired to the bike. I wired mine to the battery through a relay that shuts off when the forks are locked. That way it will never drain the battery if I forget to turn it off. Works great.
post #6 of 8 Old Aug 30th, 2006, 9:24 am Thread Starter
dwillie's Avatar
Thanks for the information. I do have a HeatToller and it works well. To keep things simple for now, I'll try using the existing outlet. I'll test it out on a nice ride this weekend. Wish I was going to CCR!! Maybe next year. d.
dwillie is offline
post #7 of 8 Old Aug 30th, 2006, 10:40 am
Thanks Dick, I didn't know about that hidden power outlet either!
Knowledge is power!
And knowing is half the battle...
Mopos is offline
post #8 of 8 Old Aug 30th, 2006, 6:11 pm
Smile Socket power
The stock socket outlet wires are way to small (about 20 gauge, I think). The immediate problem is reduced heat from your electric clothes, and too hot wires. Replace the wires with your own 16 ga. circuit direct from the battery and enjoy much more heat from your electric garments when full on!
HarvRead is offline
iWay 500c audio problem was GPS 11 Apr 26th, 2007 8:07 pm
My New Handlebar Power Outlet surfran K1200LT 3 May 13th, 2006 8:26 pm
Additional Power outlet FredR Batteries, Chargers, & Electrical 4 Mar 12th, 2006 10:32 pm
Power Point Question PGRSV K1200LT 3 Mar 1st, 2006 2:54 pm
Bike power to the trailer for accessories Dezrae Australia, New Zealand, and AsiaPac 2 Oct 25th, 2005 4:43 am
