How is this possible?? - BMW Luxury Touring Community
post #1 of 18 Old Aug 29th, 2006, 4:02 am Thread Starter
c00k1e's Avatar
Got back late ;last night after a 3 hour ride. (Had ear plugs in and sterio full blast.)
Turned off engine.
werrrrrrrrrrrrr
Constant werrring, slight vibration as well.
Thought it was the fans making an odd noise - no, it was further back
turned key to off position, disconnection all power - removed key
werrrrrrrrrrrrr
Seemed to come from near the battery - and no, it wasn't a shorting noise - it was deffinately machanical.
I started the engine up to stop the battery from running flat while I searched for a tourch and tools to disconnect battery
when I got the gear together I turned off engine
werrrrrrrrrrrrrrr
Misses came down to look as I flashed tourch about under seat.
werr...........it stopped
What in the world could THAT have been?
btw, ABS packed up on the trip as well - could that be relevant?
c00k1e is offline
post #2 of 18 Old Aug 29th, 2006, 7:26 am
Hmmmm - fuel pump? CD player? Do you have an on-board air compressor? Is your cell phone missing?
I give up - one for the beeg boyz. Hope you find the culprit and it's a cheap fix!!
post #3 of 18 Old Aug 29th, 2006, 8:14 am Thread Starter
c00k1e's Avatar
I thought of the fuel pump, but I got the feeling that was on the right near the frount. No CD, air compressor would have made that kind of noise and I really thought that somnehow it had plugged itself in, but it hadn't/ No mobile.
It's a worry that for sure
c00k1e is offline
post #4 of 18 Old Aug 29th, 2006, 8:26 am
Fuel pump would actually be just about inboard from your right shin/ankle area. Removing the key and still hearing the sound is weird. Maybe a relay is hanging up and making intermittent contact? Geez - brain fade here, so I'll watch for the gurus!
post #5 of 18 Old Aug 29th, 2006, 9:24 am
Zotter's Avatar
You say "ABS packed up" - I assume that to mean you've some type of ABS failure.
You say noise comes from near the battery.
Yup - the ABS unit is very near the battery.
My guess is your ABS unit is continuing to run. Any chance you had a hand on a brake lever? Foot lever?
In any case - I'd vote ABS for the noise source.
Either that or a very stealthy colony of bees...
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
post #6 of 18 Old Aug 29th, 2006, 10:33 am Thread Starter
c00k1e's Avatar
The ABS warning lights wouldnt go off (didnt test to see if could skid, that seemed a bit silly!) but the noise deffinately wasnt there when I stopped earlier in the trip
Is there a way of telling what the ABS problem may be - self diagnosis?
c00k1e is offline
post #7 of 18 Old Aug 29th, 2006, 11:35 am
BecketMa's Avatar
Chupa cabra. Spelling is probably way off.
BecketMa is offline
post #8 of 18 Old Aug 29th, 2006, 12:00 pm
Close enough spelling to send shivers!!!
post #9 of 18 Old Aug 29th, 2006, 2:24 pm
You may have a problem in the ABS unit, sounds like one of the solenoid valves is oscillating. Since you have a '99, there is no servo pump running as on the '02 and later, but there are solenoid valves in the unit.
post #10 of 18 Old Aug 30th, 2006, 3:24 am Thread Starter
c00k1e's Avatar
Cheers - any idea on a solution?
c00k1e is offline
post #11 of 18 Old Aug 30th, 2006, 11:02 pm
Smile
Dang, I think they all went to bed!
Possibly this might shed some light on your problem?
Good Luck
Hmmm. Here is the url: http://www.bmwlt.com/forums/showthread.php?t=11172
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Last edited by Dman; Aug 30th, 2006 at 11:10 pm. Reason: Got something screwed up on the link.
Dman is offline
post #12 of 18 Old Aug 30th, 2006, 11:29 pm
robasay's Avatar
ABS noises from my experience was a stuck relay. After the shop replaced the battery and removed the fuel tank and tank supports they were able to get to the relay at the front of the ABS unit. They removed it, put a meter on it rapped it once and put it back on. Charged the system and the relay did not falter anymore. Noise stopped ABS system showed a go and all things well. I would check the battery as it may not be holding a charge long enough and causing the relay to go spastic. Shop stated that separate relays could be ordered if need be. Good luck.
Rob Asay
99 Canyon Red Lt
"The True Red Dragon"
1982 Honda "Silver Wing"
1986 Gold Wing Interstate "Blue Babe"
1978 Gold Wing
1976 Kawasaki 900
1967 Honda 305 Scrambler
robasay is offline
post #13 of 18 Old Aug 31st, 2006, 3:19 am Thread Starter
c00k1e's Avatar
Noise has stopped of its own accord, but abs lights still flashing - slowley - is it safe to ride like this?
c00k1e is offline
post #14 of 18 Old Mar 23rd, 2008, 2:33 am
Buckelew's Avatar
Re: How is this possible??
I've had the same thing happen twice - except the whining didn't stop. I took a screwdriver and used the handle to rap the ABS relay...and it stops. But the ABS fault lights start wig-wagging and have to be reset.
When I had it reset the first time, there was no fault. I've got to take it back to have the ABS reset.
You can ride with the lights flashing, but your ABS is non-operable.
I'll be replacing the relay. Then I'll get the ABS reset.
Buckelew is offline
post #15 of 18 Old Mar 23rd, 2008, 6:29 am
PMitchell's Avatar
OK curiosity got me! Here it is . . .clicky-clicky!
pm
Ride till you can't!
"Der Weg ist das Ziel"
2011 South Africa
2016 Spain & Portugal
'18 R1200RTW
Sold in '67
PMitchell is offline
post #16 of 18 Old Mar 23rd, 2008, 7:30 am
kellenbenz's Avatar
I think I married her once!
Ron
IBA 45658 MOA167437
Total BMW miles 509,508
Goldwing miles 238,383
kellenbenz is offline
post #17 of 18 Old Mar 23rd, 2008, 11:31 am
Eric_R's Avatar
Is the brake light on?
I had mine make that sound once, the brake like was on and it continued even after the key was in the of position!
I disconnected the battery for 5 minutes, reconnected it and the problem has never happened again.
The only ABS light show I have had was due to low fluid levels in the resivour under the seat.
2002 K1200LTC Ocean Blue
Eric_R is offline
post #18 of 18 Old Mar 23rd, 2008, 3:31 pm
Steve_R's Avatar
You don't have the ABS feature anymore, but all the braking effort of the bike is still there. You may still ride the bike safely. BTDT.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
