05 LT Brown headlight wire - BMW Luxury Touring Community
post #1 of 3 Old Jul 24th, 2015, 9:37 pm Thread Starter
gbaltyn's Avatar
Any recent victims of the dreaded headlight ground wire failing recently? I believe I may be a victim and was wondering if I needed to strip off the nose cone to fix the issue correctly. Have the left Tupperware off now and it doesn't appear I have enough room or access to the spade connectors for the fix I've seen here on the site. Just wondering if anyone managed to do this correctly without the rest of the bodywork coming off. Ride safe.
gbaltyn is offline
post #2 of 3 Old Jul 25th, 2015, 10:13 pm
Re: 05 LT Brown headlight wire
Once you get the cover off the back of the light there is a disconnect and you can remove the harness IIRC. The wires go into that connector I circled.
Name:	Head light 05.JPG
post #3 of 3 Old Jul 26th, 2015, 12:36 am
Moogie's Avatar
Does this happen to the 2000 model also. Have recently lost my HID low beam. Put the standard H7 bulb back in and still had problems getting it to light up. I've ordered a new ceramic plug to replace the fried plastic one, I removed the plastic and plugged ea. connector into the bulb and it worked.
2000 Lt
800 Kawasaki
25 yrs. without
750 Suzuki
550 Suzuki
160 Honda
Moogie is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Yasushi
Headlight Brown Wire Fix saddleman K1200LT 9 Jul 20th, 2014 11:55 pm
Deluxe brown wire option.... timgray K1200LT 18 Apr 24th, 2014 7:28 pm
Hesitation and no Brown Wire on 2002???? HERKMECH K1200LT 26 Jun 13th, 2007 8:02 am
brown wire?? jmc88_2 K1200LT 1 Aug 9th, 2006 10:26 pm
The Brown Wire ATLDB K1200LT 6 May 31st, 2006 9:37 am
