What does this adjust? - BMW Luxury Touring Community
post #1 of 7 Old Jul 20th, 2015, 8:51 pm Thread Starter
anarchosteff's Avatar
I picked up a 2000 K1200LT a few weeks ago with 52K miles on it. I suspect the springs are pretty well shot since it tends to bottom out pretty easily on speed bumps and ingresses/egresses. The rear spring adjuster under the seat it pretty loose, so I suspect that I probably need to add a bit of fluid to it and crank it up to high.
Now, for my question. What the heck is this adjustment screw looking thingy on the front suspension? I'm hoping it adjust the suspension on the front, but I can't seem to find any documentation on what the heck it does?
Can one of you K1200LT veterans throw me a bone on this one?
Many Thanks,
Steff
Kissimmee, FL
anarchosteff is offline
post #2 of 7 Old Jul 20th, 2015, 9:07 pm
norton's Avatar
Re: What does this adjust?
That is your steering damper. I do not think there is any adjustment. It can be re-built though. One of this sites motor heads will chime in and correct me if I'm wrong. Good Luck with your new machine. I hope you enjoy yours as much as I do mine.
Scott
2007 LT
norton is offline
post #3 of 7 Old Jul 20th, 2015, 9:56 pm
Moogie's Avatar
Go to U-tube to watch all the maintenance videos for the LT. Replacing the oil in the adjuster might help the old shock/spring. Enjoy the bike.
2000 Lt
800 Kawasaki
25 yrs. without
750 Suzuki
550 Suzuki
160 Honda
Moogie is offline
post #4 of 7 Old Jul 21st, 2015, 1:44 am
Axle's Avatar
as others said it is not an adjuster it is for servicing the unit
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #5 of 7 Old Jul 21st, 2015, 8:42 am Thread Starter
I picked up a bottle of hydraulic jack fluid. I'm gonna try to work on the rear adjuster this weekend.
Thanks for the feedback everyone.
post #6 of 7 Old Jul 21st, 2015, 11:56 am
bmwcoolk1200's Avatar
The rear adjuster is real easy. I did mine recently. Just make sure you find some small rod like a coat hanger wire to push the plunger in before you fill it. Made a world of difference on mine. It was almost empty.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #7 of 7 Old Jul 22nd, 2015, 8:09 pm
rhawk's Avatar
Yep,
the slotted screw on the end of the steering damper is a plug.
It should have an o-ring under it if I remember correctly.
You can "overhaul" the damper with new seals & oil, (I used 5w fork oil) & it will still leak, preventing rust in the front suspension area. It's a good thing the damper doesn't do much. Looks like the little spongy thingy is missing from the damper mounting.
I notice that you've got the Spiegeler brake lines which is a good upgrade.
The original shock / spring in the front might be getting a little weak. If you change it you can use the opportunity to install a new dust boot on the ball joint (looks like it has a tear).
Rand & Susan Hawksworth
2000 K1200LT
rhawk is offline
Wont start after valve adjust........... STARFIGHTER K1200LT 1 Aug 27th, 2011 3:24 pm
Speed adjust for volume not working NCrider K1200LT 12 Jun 14th, 2011 10:02 pm
Pre-Load adjust factory suspension '01 wa1200lt K1200LT 3 Oct 26th, 2009 1:50 pm
How To Adjust Headlamp? Lopaca RT Series 8 May 24th, 2007 11:40 pm
New tires, valve adjust, spark plugs, retiredjj K1200LT 3 Jun 7th, 2006 11:29 am
