Oil Weep from Engine Leading Edge - BMW Luxury Touring Community
 1Likes
  • 1 Post By norton
post #1 of 9 Old Jul 18th, 2015, 11:08 am Thread Starter
deputy5211's Avatar
Oh, mighty oracles of wisdom, I come seeking knowledge.
On leading edge of my 2005's engine, there is a rounded cover with some bolts in a somewhat-circular pattern. What lies under this cover?
I have a tiny bit of oil weeping from the bottom edge of this. Something to be concerned about, or just put a new gasket or o-ring on? Will a bunch of oil drain out when removed, as in, should I plan on doing an oil change when I take care of this?
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #2 of 9 Old Jul 18th, 2015, 1:19 pm
Re: Oil Weep from Engine Leading Edge
Not an Oracle Tony but only thing on front of engine is the combination oil pump and water pump, the oil pump is closest to engine and between the oil pump and water pump on the bottom there is a drain hole in case either seal starts leaking.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #3 of 9 Old Jul 18th, 2015, 8:58 pm
norton's Avatar
Pictures makes diagnosis a lot easier.
Patric likes this.
Scott
2007 LT
norton is offline
post #4 of 9 Old Jul 19th, 2015, 11:27 am Thread Starter
deputy5211's Avatar
Is small amount of oil weep along bottom of arc anything to be worried about?
I presume the oil and water pumps are isolated to prevent oil from getting into coolant and coolant from getting into oil.
I do not believe any cross contamination at this point as last two oil changes the weepage has been there and Blackstone Labs oil analysis report did not list coolant or water in engine oil.
Am I going to drain coolant and/or oil by opening that cover to change gasket? Anything special I need to anticipate when removing that cover to change the gasket/o-ring?
Anyone have p/n for the gasket?
Antony (Tripod)
post #5 of 9 Old Jul 19th, 2015, 1:40 pm
The pumps are separated with an air gap hence the drain hole between them, the only way to get a mix is with a bad head gasket.
If not dropping only wet maybe one of those things that can be watched
Pic would be nice
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #6 of 9 Old Jul 19th, 2015, 7:15 pm
If you pull the cover you expose the impeller of the coolant pump. There should be no oil there. Could be from the oil pressure sending unit or the timing cover. If it is not a serious leak I would just monitor it.
post #7 of 9 Old Jul 20th, 2015, 2:02 pm
jers99lt's Avatar
Hi Tony,
Not that I'm an expert, at all, but I had the same happening to my '99 from the cam/timing chain cover. The large headed bolds don't get tightened all that tight and there is a small amount of oil that will be sitting on the bottom of the cover and towards the front of the bike. I tightened the lower left bolt just a wee bit more and the leak appears to have abated. I'll continue to monitor and may need a new gasket in the future.
Have fun,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #8 of 9 Old Jul 20th, 2015, 3:32 pm
CR125Honda's Avatar
My guess is your referring to the water/oil pump.
Had that issue on my 03 a while back.
Relatively easy fix.
Replace #27 in the pic below,
Use Yamabond #4 (or sealant of your choice) on the metal sealing surfaces.
I'd do an oil & coolant change while your there.
Enjoy the journey!
2003 K1200LT
2005 Yamaha R1
1975 CR125 Elsinore
1974 Honda CB750K4
1974 H2 750 Kaw
1970 Triumph 650
1961 Pan/Shovel
Couple Mini Trail's QA' & CT's
CR125Honda is offline
post #9 of 9 Old Jul 21st, 2015, 1:51 am Thread Starter
deputy5211's Avatar
Ken,
Yes, that is the area. Oil is weeping from under #20, bottom-most bolt and about 1/2" either direction of the lowest.
Due for lubricant change anyway, just got back from 4,000 trip Dallas-L.A.-SFO, and back and no doubt the high speeds and desert heat/dust took their toll on these fluids. May as well change coolant, may be original.
Antony (Tripod)
Bosch 72161 oil filter WARNING! kellenbenz K1200LT 29 Feb 20th, 2018 10:00 am
How To Do A $65 Oil Change For $13 southern_nj K1200LT 109 Sep 19th, 2013 5:16 pm
Seeing Oil Level japgen RT Series 29 Dec 8th, 2012 5:50 pm
