Front End Shake - BMW Luxury Touring Community
post #1 of 8 Old Jul 13th, 2015, 8:36 am Thread Starter
jtalka's Avatar
Question Front End Shake
This is a new one on me but I suspect that you guys out there will know about it.
Yesterday was HOT in New Jersey.. I was out on my new (to me..) 2007 K1200LT.. I was heading down the road and did something which I never do, and that is take both hands off the handlebars..basically to get some air flow through my fingers.... Much to my amazement, the front end of the beast started to oscillate, gaining side to side momentum. Quickly put my hands back on the bars and all was well...What's that all about...? I've been riding for years and have never experienced anything like this, again, not that I ride hands free except for perhaps an instant or two...
I recall something about front end oscillation on this board before and was wondering what causes it and what I need to do to correct.. Was a bit un-nerving.... Thanks guys, Joel
Joel Talka
Glen Gardner, NJ
2007 K1200LT - Blue
1978 Corvette Pace Car Replica - ZZ383/M22
jtalka is offline
post #2 of 8 Old Jul 13th, 2015, 8:44 am
Re: Front End Shake
Front tire, radial?
Low air pressure?
Later LT's use bias ply tires.
HTH....Randy
2006 LT
Magnesium Shwarz Metalic
Bountiful, Utah
2006lt is offline
post #3 of 8 Old Jul 13th, 2015, 10:43 am
amindtat's Avatar
Re: Front End Shake
Steering damper?
amindtat is offline
post #4 of 8 Old Jul 13th, 2015, 1:21 pm
norton's Avatar
Re: Front End Shake
It is normal. My 07 shook when she was new with 500 miles on it the first time I let go of the bars at about forty during deceleration, woke me up pretty quick. Thirty K miles later it still does it. It has never even hinted at shaking as long as one hand was on the bar. I'm sure there are other factors, tire wear, worn suspension, bad dampers that may make it a little worse but the fact is when conditions are right and hands are off the bars the front wheel will shake. As far as I'm concerned there should be no concern because you should have at least one hand on the bars at all times. Now if it shakes at cruise or during acceleration holding the bars something is definitely wrong.
Scott
2007 LT
norton is offline
post #5 of 8 Old Jul 13th, 2015, 3:46 pm Thread Starter
jtalka's Avatar
Re: Front End Shake
Guys, Thanks for the insights... Like I said, I've heard of this before on this board as I recall... My bike is an '07 too with only 11K on the clock. It has Metzlers on it and I keep them a few pounds above spec... Needless to say, my hands will be on the bars!! Joel
Joel Talka
Glen Gardner, NJ
2007 K1200LT - Blue
jtalka is offline
post #6 of 8 Old Jul 13th, 2015, 5:18 pm
Re: Front End Shake
My 2006 is rock steady at any speed.
Bridgestones rock.
later..Randy
2006 LT
Bountiful, Utah
2006lt is offline
post #7 of 8 Old Jul 13th, 2015, 8:14 pm
Re: Front End Shake
I have had it come and go and it was always related to tires. As they wear or become unbalanced it will usually happen as you slow from 45 MPH with hands off the bars. It has always gone away with a new front or a re-balanced front except one time when the new tire was slightly out of round. I am on rear number 13 and front number 8 now. All bikes with worn tires will do this at some unique speed and it will never be felt if you never take your hands off the bars.
post #8 of 8 Old Jul 13th, 2015, 9:27 pm
Re: Front End Shake
Originally Posted by norton View Post
It is normal.
The others have already given you the heads-up, I'd only add that while its a common occurence if there is a front tyre issue - and it can happen with brand new tyres, it is anything but "normal" and shouldn't really happen.
Sometimes you can't get rid of it... its the front tyre = frustration.
Sometimes you get a new front, properly installed and balanced, and the problem is gone (insert happy dance).
Only way I've been able to reduce it with a problem tyre is by installing a HyperPro RSC damper... expensive but you can reduce the effect.
I hated that I could feel it wobbling through sweeping corners (even with a new tyre), hence spending cash on the expensive active damper.
Front Tire wear News mlempenau Tires 14 Nov 21st, 2011 11:07 am
Is this Front Brake Line Normal? rovero K1200LT 7 May 27th, 2011 12:15 pm
Z6 on the Front LT LAF Tires 2 Jul 10th, 2010 8:16 am
New front oil leak while on the road. Advice? TomD K1200LT 12 Aug 20th, 2007 2:24 pm
Frontend Shaaakes motosaurs K1200LT 43 Aug 23rd, 2006 12:48 pm
