intermitent problem with ABS lights blinking - BMW Luxury Touring Community
 4Likes
  • 3 Post By oldbmwrdr
  • 1 Post By jzeiler
post #1 of 5 Old Jul 9th, 2015, 1:38 pm Thread Starter
OK, have a 2001 K1200 LT that has the ABS II breaking system. I seem to get the 2 ABS lights blinking on occasion but only when I am cursing on the highway at 75 to 80 mph. These seems to be no degradation on break function and the fault disappears once the ignition is turned off and restarted. Battery is at full charge and the rear master cylinder is full. Checked with GS/911 and see rear wheel speed censor fault has occurred but is no longer present. Any thoughts or ideas of where this may be coming from?
oldbmwrdr is offline
post #2 of 5 Old Jul 9th, 2015, 2:02 pm
bmwcoolk1200's Avatar
Re: intermitent problem with ABS lights blinking
I will let the guru's respond with more solid tech info but if you have an intermittent rear speed sensor fault, I would start there. Remove it, clean it and if there is an adjustment procedure for clearance, I would do that and see if it continues. I also have a 2001 ( Brembo calipers) and the brake system does not use the servo brake assist but a modulator so if that system fails, you still have fill brake function, just no anti lock. Since you actually have a code, I would start there and see if you have a bad connection at the connector for that sensor or a lot of gunk built up on it. If you clear the code, does it come back on the next check after the fault occurs even if it isn't currently present when you check?
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #3 of 5 Old Jul 9th, 2015, 7:45 pm
It is unusual that the fault self clears as that is not normal operation for the system. I would suspect a pinched wire in the rear sensor line some where. Look for a tight cable tie and strip back the insulation to check for a cracked wire at that location.
post #4 of 5 Old Jul 14th, 2015, 1:50 pm Thread Starter
well looks like the problem is solved .... seems that the air gap on the sensor was a bit too large .... made the adjustment and have not seen the problem again .... yet.
radar41, Patric and bmwcoolk1200 like this.
post #5 of 5 Old Jul 15th, 2015, 9:41 pm
Thanks for the follow up report.
Patric likes this.
Flashing ABS lights (my turn) SilverBuffalo K1200LT 2 Apr 18th, 2014 5:23 pm
ABS Warning Lights and Radio Indicator JeffB K1200LT 16 Oct 28th, 2011 9:59 am
abs lights blinking dcumberland RT Series 27 Sep 19th, 2009 5:18 pm
PIAA lights vs . . . (product review) Seattle Lighting 7 Jul 11th, 2009 2:13 pm
Hella FF50 Driving Lights installed unleashd Lighting 22 Aug 21st, 2006 3:11 pm
