Dash lights - BMW Luxury Touring Community
 1Likes
  • 1 Post By cws
post #1 of 6 Old Jul 8th, 2015, 10:26 pm Thread Starter
jaskjb's Avatar
Dash lights
Went to work today, and when I got to work I noticed that the high beam indicator and both turn signal lights were on. The turn signals both work and the bulbs are ok. When the turn signals are flashing the high beam also flashes. High and low beams both work. No other issues except the dash lights don't work, and they did this morning. Any thoughts? I plan to hook up the gs911 tomorrow morning and see what if anything it says.
On my 2000 k1200 LT
Jim G - Rochester, MN
BMW MOA #123976
2000 K1200LTC
jaskjb is offline
post #2 of 6 Old Jul 9th, 2015, 2:33 am
Axle's Avatar
Re: Dash lights
I would suspect a bad earth which is feeding back into the cluster
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #3 of 6 Old Jul 9th, 2015, 5:21 am
Re: Dash lights
Is that what you call a cluster-fu....... ooops better not, someone told me to keep it clean.
Hilton likes this.
post #4 of 6 Old Jul 9th, 2015, 7:47 pm
Re: Dash lights
Check for melted wires or corroded ground (brown wires) up in the headlight area this is usually what causes a high beam light to flicker
post #5 of 6 Old Jul 12th, 2015, 5:14 pm Thread Starter
jaskjb's Avatar
Re: Dash lights
Update: all lights work - high beam, low beam, turn signals, flashers etc. went looking for a bad ground. So far found none. When the bike is running - the turn signal dash bulbs(x2) and high beam indicator bulb is on constantly. Only the dash indicators, not the actual bulbs. When making a turn and signaling both the appropriate signal indicator and the high beam indicator flash at the same time. Also, there are no dash background lights. All the dash indicators that come on when the key is turned to on seem to work. Headlights are standard, no hid.. I called several service departments (none in Rochester) and no one has seen this. I am stumped.....
jaskjb is offline
post #6 of 6 Old Jul 12th, 2015, 7:23 pm
Axle's Avatar
Re: Dash lights
does it have a trailer plug on the back? I still think it's is an earth problem, dash back ground lights I believe i read somewhere, have a light sensor they come on at night.
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
Dash Lights stevea2980 K1200LT 16 Feb 21st, 2019 6:55 pm
Dash lights on...NO KEY SoberBiker K1200LT 0 Jul 1st, 2011 7:01 am
No dash lights...Most of the time Family_fun K1200LT 4 May 12th, 2010 4:12 pm
PIAA lights vs . . . (product review) Seattle Lighting 7 Jul 11th, 2009 2:13 pm
Hella FF50 Driving Lights installed unleashd Lighting 22 Aug 21st, 2006 3:11 pm
