Angled valve stems - BMW Luxury Touring Community
post #1 of 9 Old Jul 4th, 2015, 11:37 pm Thread Starter
james216's Avatar
Angled valve stems
Next time i put new rubber on. I want to install new metal 90 valve stems. The straight ones are a pain to get some air chucks on. Is this recommended? And. Whats the part# for the replacement O2 sensor?
2004 K1200LT. Big Mama
I'm a 4 percenter.
james216 is offline
post #2 of 9 Old Jul 5th, 2015, 12:52 am
Re: Angled valve stems
I believe the angled or 90 degree valve stems are okay if not too long. There has been some issues with fitment due to the structure of the wheels.
Bosch O2 sensor.
Buff8stuff is offline
post #3 of 9 Old Jul 5th, 2015, 2:47 pm
FWIW I used angled ones (not 90 but 45) and ended up going back to short straight ones. Just found it easier all around.
post #4 of 9 Old Jul 5th, 2015, 3:10 pm
Atomicman's Avatar
Ya just get a 90 degree adapter!
Here's one. Ya don't leave it on when riding, can cause leaks!
Adventure Motorcycle Depot - Hornig 90 Degree Valve Stem Adapter
The Older I Get, the Faster I Was!
2009 "Fully Farkled"Black Metallic Sapphire RT
Atomicman is offline
post #5 of 9 Old Jul 5th, 2015, 5:45 pm
6speedTi's Avatar
I have one for my RT. The problem is when you install it or remove it after servicing the tire it leaks out too much air and you lose the pressure and your back where you started from. Leaving it on is no good because it's big and it may get lose or get hit with debris while riding.
2012 R1200RT
1985 T5 Vespa
2007 Piaggio X9 500 EVO
6speedTi is online now
post #6 of 9 Old Jul 5th, 2015, 6:27 pm
Atomicman's Avatar
I don't have that problem. I unscrew it until just before the air is leaking out and then move my fingers around the retainer to unscrew the last bit quickly in one turn.
post #7 of 9 Old Jul 5th, 2015, 10:21 pm
GaryEm's Avatar
James the part# Bosch 13475 is what you need for your 02 sensor
Gary
2003 K1200LT
GaryEm is offline
post #8 of 9 Old Jul 5th, 2015, 10:28 pm Thread Starter
james216's Avatar
The 45 would be fine. So no problems with these wheels?
I'm a 4 percenter.
james216 is offline
post #9 of 9 Old Jul 6th, 2015, 8:41 am
cbpip's Avatar
https://www.kurveygirl.com/shop/prod...h7cn4p3pgik862
Found these from Kuveygirl to work fine on the lt. Just stay away from the aluminum ones that have isues with clearance on the rims center molding.
76 Honda 750 four-departed
65 Pan head (gone)
72 Rickman 6 day Enduro
BMWMOA # 189093
BMWBMW LOCAL CHAPTER Member
BMW MARS CHAPTER Member
BMWRA # 41568
cbpip is offline
Angled Tire Valve Stems Kra961 K1200LT 21 Sep 30th, 2012 7:37 pm
Metal valve stems sittonb K1200LT 27 Aug 23rd, 2011 12:15 am
Angled Billet Valve Stems dougholck GS Series 0 Aug 5th, 2008 10:44 am
Angled valve stems Shogun54 Bike Talk 13 Jun 7th, 2006 11:40 am
angled valve stems tmgs K1200LT 33 Mar 13th, 2006 8:15 am
