Bleeding Clutch - BMW Luxury Touring Community
 4Likes
  • 1 Post By Voyager
  • 2 Post By jzeiler
  • 1 Post By JNW003
post #1 of 15 Old Jul 4th, 2015, 8:26 am Thread Starter
GDRDoc's Avatar
Bleeding Clutch
How hard is it to bleed the clutch lines? I think I have air in my clutch system as the lever has a lot of play to dis-engage. I didn't know it go low until when I went to apply the clutch, it traveled most of the way. Then I knew I had a problem. I filled up the reservoir. I know I don't have a leak as there are no spots on the garage floor.
[img]
1/7/7/5/8/
1998 Honda Shadow 65K - sold
2003 BMW K1200LT - 10060K
IBI Member (1K Miles in 17 Hrs)
GDRDoc is offline
post #2 of 15 Old Jul 4th, 2015, 9:01 am
Re: Bleeding Clutch
It is a nuisance the first time as you have to remove the grub screw and replace with a bleed screw. After that it is pretty easy, just like bleeding brakes. I use a bleeder bag and that really lessens the chance of pulling air back into the system.
Was the bike tipped over recently or anything else unusual?
Patric likes this.
post #3 of 15 Old Jul 4th, 2015, 12:19 pm
Re: Bleeding Clutch
Gary go over to the BMW motorrad club web page: First Family Member and click on "service" then (Maint/Videos) and you'll find a step by step video on how to bleed your clutch.
Have fun.
Bajasteve is offline
post #4 of 15 Old Jul 4th, 2015, 2:39 pm
Re: Bleeding Clutch
If the reservoir level is dropping you have a leak. During the normal course of wear on the clutch disk the fluid level will rise. The leak could be at the slave cylinder and right into the clutch with no drips on the floor. That is where the weep hole comes in handy.
gunny and Patric like this.
post #5 of 15 Old Jul 4th, 2015, 5:13 pm
JNW003's Avatar
Re: Bleeding Clutch
Once you get to the point of needing to bleed the clutch, I found that using a Speedbleeder in place of the grub screw makes life much easier.
Dave Beck
'16 K1600GTLE
'07 K1200LT (sold 9/24/16)
JNW003 is offline
post #6 of 15 Old Jul 4th, 2015, 10:48 pm Thread Starter
GDRDoc's Avatar
Re: Bleeding Clutch
Thank you all for the replies. I did find a link on the BMW of Illinois club website on how to bleed the clutch. I removed the grub screw fitting and just let the hose drain into a bucket and refilled the reservoir while pumping the clutch handle. I did this about 5 times (refilled the reservoir) and did notice some air coming out of the reservoir. Now the clutch will disengage the rear wheel about halfway. How far should the travel be as optimum? I already have an apt to have the dealer check the slave unit as this problem just occurred recently. And no, the bike didn't tilt or fall over.
[img]
1/7/7/5/8/
GDRDoc is offline
post #7 of 15 Old Jul 5th, 2015, 2:57 pm
Re: Bleeding Clutch
Half way sounds about right and I just went for a ride today but wasn't paying that close attention to it.
post #8 of 15 Old Jul 6th, 2015, 11:36 am
bmwcoolk1200's Avatar
Re: Bleeding Clutch
Now that you have it bled, keep a very close eye on it for any changes in the reservoir level. The slave cylinder has a gasket between it and the engine/tranny so leaking will not be seen if the weep hole mentioned by jzeiler has not been drilled and you will only know of a problem after your clutch has been coated with oil as that is the only place the leaking oil has to go without the weep hole to indicate a slave leak issue.
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #9 of 15 Old Jul 12th, 2015, 6:52 am Thread Starter
GDRDoc's Avatar
Re: Bleeding Clutch
jzeiler
OK.. Thank you.. I was wondering what the weep hole was for and now I know if I did have spots on the floor, it'll tell me the slave unit is leaking. I just hope now when I take the bike in, that I didn't burn up the clutch with the fluid on it.
[img]
1/7/7/5/8/
GDRDoc is offline
post #10 of 15 Old Jul 12th, 2015, 6:53 am Thread Starter
GDRDoc's Avatar
Re: Bleeding Clutch
bmwcoolk1200
OK.. Thank you... I think I'm going to have the dealer drill the hole
[img]
1/7/7/5/8/
GDRDoc is offline
post #11 of 15 Old Jul 12th, 2015, 7:11 am
mtrevelino's Avatar
Re: Bleeding Clutch
bmwcoolk1200
Good luck with that! My dealer refused to drill the hole when they replaced my rear main seal, along with the clutch and the slave cylinder.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #12 of 15 Old Jul 13th, 2015, 4:18 pm
Re: Bleeding Clutch
Yep, I think that is going to be the standard dealer response. If you want it, you are going to either do it yourself or find someone who can do it for you.
Gordon
Sugar Hill, GA
post #13 of 15 Old Jul 13th, 2015, 5:00 pm Thread Starter
GDRDoc's Avatar
Re: Bleeding Clutch
I can only ask.. if not, I'll just keep an eye on it..
[img]
1/7/7/5/8/
GDRDoc is offline
post #14 of 15 Old Jul 13th, 2015, 5:15 pm
Re: Bleeding Clutch
That is exactly the issue the weep hole corrects. You don't get to see the oil leaking from the slave till after it makes its way to your clutch so there is no way to keep an eye on it.
It never hurts to ask but that them drilling the hole would be equivalent to them admitting there was an issue that the weep hole could provide an early indication of. I don't recall reading of someone actually having a dealer perform the weep hole drilling but I won't say never.
Gordon
Sugar Hill, GA
post #15 of 15 Old Jul 13th, 2015, 6:40 pm
JNW003's Avatar
Re: Bleeding Clutch
Plus they get to sell additional parts and labor to replace clutches....
bmwcoolk1200 likes this.
Dave Beck
'16 K1600GTLE
JNW003 is offline
Clutch Fluid Bleeding Problem judgejoe K1200LT 11 Jun 11th, 2011 5:13 pm
Clutch Bleeding Problems(fluid won't come out) RickyK12 K1200LT 5 Aug 21st, 2007 9:59 am
