retro fit relay - BMW Luxury Touring Community
 1Likes
  • 1 Post By mexicoboy
post #1 of 4 Old Jul 3rd, 2015, 11:32 am Thread Starter
Angry retro fit relay
Howdy. Well back again with a question, of course. BMW Cancun had to order me a replacement relay as they did not install the retro fit I had purchased from 2wheel pros. My problem is they only ordered the relay, not the wiring harness. I have the instructions from BMW on the install process but it does not state which pin to use only which color wire. Not sure slide on connectors is the way to go anyway.
So does anybody know of a way to get just the harness connector as I cannot find it listed as a separate part. Grrrrrrrrr
This is relay number 61357655540.
mexicoboy is offline
post #2 of 4 Old Jul 3rd, 2015, 12:40 pm
Patric's Avatar
Re: retro fit relay
It might be this http://www.maxbmwmotorcycles.com/fic...57663945_1.pdf
....or not
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #3 of 4 Old Jul 3rd, 2015, 12:45 pm
sailor's Avatar
Re: retro fit relay
To the best of my knowledge, also confirmed by BMW parts catalog, you CANNOT buy the small wire harness separate. You either buy the new relay alone (you part number above), OR you buy the retrofit kit that has both (relay and adapter harness).
Only other option is a parted bike on EBAY, but in most cases they will sell the whole harness of the bike. In addition, unless you find a 1999-2001 parted bike that has been retrofitted, you will not obtain the small adapter harness as the 2002-2009 do not have adapter harness - these came from factory with new relay (starting with VIN ZD77402 for USA market).
See photo in Item 1 here on MAX-BMW parts fiche:
MAX BMW Motorcycles - BMW Parts & Technical Diagrams - K1200LT 99-04 (89V3)
John (Montreal, CANADA)
sailor is offline
post #4 of 4 Old Jul 3rd, 2015, 1:47 pm Thread Starter
Re: retro fit relay
Yeah, thanks for looking, as I suspected, SOL. New battery should do it for awhile anyway and now know to keep on tender.
Patric likes this.
2002 K1200LT Starter Relay Issue.. resolved I think jimbotronics K1200LT 15 Apr 22nd, 2018 9:25 am
Another fuel issue (relay? pump?) bsellers K1200LT 12 Jul 30th, 2016 10:04 am
Wiring info needed for the redesigned starter relay. zuchero K1200LT 27 Jun 26th, 2016 9:00 am
Help with switch idea jarhead354 K1200LT 13 Feb 27th, 2009 12:18 pm
Oops, I let out the magic smoke jkersh1 K1200LT 4 Oct 27th, 2005 9:36 pm
