New EBC rear disc - BMW Luxury Touring Community
 2Likes
  • 1 Post By jzeiler
  • 1 Post By Steve_R
post #1 of 12 Old Jul 2nd, 2015, 5:43 pm Thread Starter
2003BMWK1200LT's Avatar
New EBC rear disc
Is this new drilled rotor by EBC worth the upgrade or wise to keep the stock rotor with small wear and just install new brake pads? Thanks, John
EBC Pro-Lite Brake Rotor - Rear MD615 https://www.amazon.com/dp/B0036GDL2O..._Q.ALvb34T57GM
2003BMWK1200LT is offline
post #2 of 12 Old Jul 2nd, 2015, 7:23 pm
Re: New EBC rear disc
If it ain't broke, don't fix it! The only reason to change it out is if it has the famous cowbell clanging going on, or if it's really worn. I have an EBC now, as it's cheaper, but probably not the quality steel that BMW uses. I just replaced the rear pads today, and I only use BMW, they cost more but seem to work better than all the others I've tried.
BMRBOB
bmrbob is offline
post #3 of 12 Old Jul 2nd, 2015, 7:54 pm
Actually it is harder material than the stock one. I wore two of those out and have put over 50 K on the USED EBC I got and very little wear compared to stock and no clang or squeal.
radar41 likes this.
post #4 of 12 Old Jul 2nd, 2015, 8:55 pm
Steve_R's Avatar
I've put an EBC rear rotor on all three of my LTs. In my opinion it is far superior to the non-drilled BMW rotor. I get better stopping wet or dry, seem to be better pad wear and like John I don't have to listen to the squeal.
radar41 likes this.
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #5 of 12 Old Jul 3rd, 2015, 2:26 pm Thread Starter
Thanks much for the input! This is such an amazing resource for us LT owners!!!
post #6 of 12 Old Jul 4th, 2015, 10:54 pm
How difficult is it to get the rotor disk bolts out?
Steve
stevekremer is offline
post #7 of 12 Old Jul 7th, 2015, 8:51 pm
silverlt2002's Avatar
Steve
I used a Mapp Gas torch to heat them up and melt the locktite and they came right out. Others have had problems but they are pretty easy to drill off. You get new screws with the EBC disk so you only need the ring off of the old disk.
Steve Green
US Army (Ret)
2002 KLT
Titan Silver
silverlt2002 is offline
post #8 of 12 Old Jul 7th, 2015, 8:56 pm
Definitely use some heat. Even the latent heat of a spirited ride should be enough to soften the loctite. Go slowly on the losening and keep the Allen bit straight. I have done a couple dozen and only had to drill one out. Just remember the bolts only hold the rotor on while the wheel is off. So even if you bugger one - one is enough to hold it on.
post #9 of 12 Old Jul 8th, 2015, 12:08 pm
Put the EBC on about a thousands miles ago. Bike is much quiter without the clanging and banging. I used the Mapp gas too for the bolts and the ABS ring. Easy Peasy with some heat!
2003 LTE ( Big Silver Cow)
2000 Buell S3T (Little Black Beauty)
198? Yamaha 650 (Sold )
1974 Honda CB 750 (wish I still had it!)
1972 Honda CB350 (Crashed)
197? Honda 50 Mini Bike (Long Gone)
Newbuellertoo is offline
post #10 of 12 Old Jul 8th, 2015, 9:17 pm
PMitchell's Avatar
Did mine a couple of years ago and used a standard propane torch.
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is offline
post #11 of 12 Old Jul 9th, 2015, 8:43 am
norton's Avatar
John is right, the metal on stock BMW rotors is soft, to soft. I had one put on under warranty for the ten bolt to five bolt rotor re-call to cure the braking squeal. The metal on the surface of the rotor actually pills up in little balls on the surface of the rotor(see Imgur pics). I have to take my roto zip every now and then and grind them off as they will grow bigger and ruin the pads. I showed the pics to the BMW dealer who showed the pics to BMW rep and of course he said it was the non OEM brake pads. Well, stupid rep, they were your OEM pads. Then he said he would look into it and get back to the dealer and that never happened. The dealer was good and ordered a new rotor and pads because he new BMW was a dead end , no cost to me and that new one does the same thing so I just deal with it until time for a new EBC rotor. On the five pics of the rotor you will see on the first pic it shows up real clear, the other pics you have to look close to see the small dots which is the metal building up. I tried to tap them with screw driver to see if they would pop off but the are fused to the surface of the rotor
Imgur
Scott
2007 LT
norton is offline
post #12 of 12 Old Aug 10th, 2015, 7:09 pm Thread Starter
Thanks to all. I did replace the stock rotor with an EBC and am happy with it. I used map gas and the first bolt came out easy. The second was a struggle. It stripped quickly. I used a Dremel to grind a straight line in the head. Then I used a large flat head screw driver and an adjustable wrench on the screw drivers square shaft to break it loose. I re used it with Loctite and ordered 2 new ones for future just to have on hand.
Another Rear Drive Bites the Dust - Question lad K1200LT 63 Jul 19th, 2013 1:34 pm
Thought I had blew by rear drive slmorley K1200LT 2 Oct 29th, 2010 11:51 am
Rear Disc Rotor Mounting Bolts theoldone K1200LT 14 Jul 29th, 2010 1:28 pm
EBC rear disc rotor gstevens K1200LT 14 Jul 8th, 2010 2:30 pm
Linked brakes negative bmwrubbercow K1200LT 19 Aug 4th, 2006 4:00 am
