Greasy Final drive - BMW Luxury Touring Community
post #1 of 9 Old Aug 23rd, 2006, 10:38 am Thread Starter
Greasy Final drive
Hi Guys
Got back last night from a 3 day 2100 mile trip. Noticed this morning a film of oil over the swingarm, final drive and rear wheel. Basically everything back of the passenger pegs.
Will swing by the dealer tomorrow. Prefer to go armed with some info - any idea of the cause?
FWIW was a high speed trip - averaged 75 mph including stops, and the last 600 miles was in a torrential downpour.
RoyvL is offline
post #2 of 9 Old Aug 23rd, 2006, 12:57 pm
Originally Posted by RoyvL
Hi Guys
Look where it starts to get oily... problem is forward of that point.. If it originates at the rubber boot I would expect a seal in the swingarm.. If the swingarm boot itself is oily I would suspect a transmission or engine seal. See if you can determine from underneath how high it goes... You can also check your gearbox and engine oil and see if either is low... or up to level... if both are at the correct level you may have unknowingly hit an oily patch on the road.. If both are up to level.. you need to clean everything up and pay attention as you ride.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #3 of 9 Old Aug 23rd, 2006, 1:05 pm
The seal at the front of the final drive can sometimes leak, as well as the seal at the rear of the transmission. Yours may be a tranny seal since the front of the swingarm is also dirty.
They should be able to determine the cause and swap out the seal pretty easily.
post #4 of 9 Old Aug 23rd, 2006, 3:55 pm
Road Grime
You mentioned downpour it could be road grime
PeteM
PeteM is offline
post #5 of 9 Old Aug 24th, 2006, 1:33 am Thread Starter
Checked oil level - has moved from top of sight glass to the middle.
Does not usually use oil between services, so most likely an engine seal.
RoyvL is offline
post #6 of 9 Old Aug 24th, 2006, 3:56 am
Daman858's Avatar
The LT does not, as a general rule, use any oil. With your bike on the sidestand, the oil level should be halfway on the site glass. On the center stand, it should be at the top of the site glass. It is best to leave the bike sit for a time before checking the oil.
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #7 of 9 Old Aug 24th, 2006, 4:30 am
check your rear shock as well
K12LT03 is offline
post #8 of 9 Old Aug 24th, 2006, 7:12 am Thread Starter
Should have made myself clearer - I did check it before the trip on the centrestand - was almost at the top. On return was a hair above the middle.
RoyvL is offline
post #9 of 9 Old Aug 24th, 2006, 7:15 am Thread Starter
Shock looks good.
Dealer can only see me on friday
RoyvL is offline
Final Drive murray K1200LT 22 Sep 28th, 2008 9:02 am
So what is a final drive worth ? Patric K1200LT 12 Jun 27th, 2007 3:47 pm
final drive issue budzee K1200LT 1 Jul 25th, 2006 8:15 am
R1100RT Final Drive Oil Leak markbreen Other R-Bike Discussion 3 Jul 12th, 2006 9:11 am
Oil on the final drive boot - Sorry LONG ATLDB K1200LT 10 Mar 14th, 2006 3:14 pm
