replacing brake lines - BMW Luxury Touring Community
post #1 of 4 Old Jun 21st, 2015, 12:07 pm Thread Starter
Hey all, I sprung a leak in one the rear brake lines on my 2000 Lt...I bought some speiger replacements and was on my way to swapping them when I ran across this...replacing brake lines-gedc0153.jpg
I don't have a clue as to what that do-hicky is where the bleeder valve is supposed to be. Does anybody know what this is?!!!
qdog1016 is offline
post #2 of 4 Old Jun 21st, 2015, 12:38 pm
sailor's Avatar
Re: replacing brake lines
Originally Posted by qdog1016 View Post
Hey all, I sprung a leak in one the rear brake lines on my 2000 Lt...I bought some speiger replacements and was on my way to swapping them when I ran across this...Attachment 83058
This so-called "filling adapter" has been used on production at factory for many years. You will need to get a separate bleeder (Metric 10 with pitch thread 1 mm) to thread either at:
1) hole under the small hex cap screw (bleeder need short bottom tip for this to work)
2) hole under the whole filler adapter (normal tip bleeder)
WARNING: the small hex cap screw is easy to strip as it is hard to undo because corrosion gets inside threads. On the other hand the filler adapter is ever worse as it is installed at factory with strong thread-locking compound (need heat to remove in many cases).
See attached PDF for Service-Bulletin explaining the issue...
File Type: pdf Brake_and_clutch_BLEED_SCREWS_modification.pdf (1.10 MB, 82 views)
John (Montreal, CANADA)
sailor is offline
post #3 of 4 Old Jun 21st, 2015, 1:49 pm Thread Starter
Thanks much!
qdog1016 is offline
post #4 of 4 Old Jun 22nd, 2015, 3:34 pm
BMWCharlie's Avatar
I replaced the brake lines with Spiegler SS lines on my 99 last winter. I went to my local, friendly dealer and asked about the same port. He sold me a plastic, screw-in adapter for a couple of bucks. (Least expensive BMW dealership repair visit in history. I know.) You only need to pry off the cover/cap, screw in the plastic adapter, and use the fitting to bleed the fluid. When you've finished the new line installation, unscrew the adapter and pop the cap back on. Done. Put the adapter someplace where you can find it for the next time you bleed the brake lines.
The dealer said not to just leave the adapter in place as the pointed end displaces the spring-loaded ball bearing valve at the bottom of the filler. Leaving the adapter in place could allow the spring to fail while letting air/humidity to potentially enter the circuit.
I know there are all kinds of threads here about how to remove that factory-installed filler, but this little device is way, way less complicated. And, you can't mess up the factory piece, costing you even more to fix that.
Charlie
99 K1200LT
85 R80RT
81 R100RS (Sold it 4/10)
03 Moto Guzzi V11 LeMans
BMWCharlie is offline
air in brake lines? tonvanunen K1200LT 8 Dec 15th, 2014 4:37 pm
Stock Brake Lines rhawk K1200LT 1 Feb 6th, 2013 11:22 am
BMW Bulletin on Installation of Steel Brake Lines rdwalker Bike Talk 5 Feb 13th, 2011 12:25 am
Spiegler brake lines: angle of the rear banjo fitting? rdwalker K1200LT 8 Mar 13th, 2010 7:32 pm
After market brake lines, Melvin? BecketMa K1200LT 6 Sep 5th, 2008 8:32 pm
