Coolant Temp - BMW Luxury Touring Community
 2Likes
  • 1 Post By deanwoolsey
  • 1 Post By Voyager
post #1 of 9 Old Jun 18th, 2015, 9:10 am Thread Starter
FrankNitti's Avatar
Coolant Temp
Was in the mountains of New Mex. yesterday when I noticed that the temp gauge started to tick upwards....any reason for this?
All across the states it ran about a needle width below center line, now in the mountains it's about about 2 needles width above center line. Seems to settle out at that point and maybe even drop a little.
Is it because the engine is just having to work harder or maybe a little less air ?
Mainly just want some reassurance from someone that this is a common problem, last thing I want is to be broke down 2000 miles from home.
__________________________________________________ _________
John aka Frank Nitti
2003 K1200LT-E
1993 HD Fatboy...Gone, But not Forgotten
2000 Honda Gold Wing/Motor Trike Conv.
MOA #186960
Some people try to turn back their odometers. Not me; I want people to know 'why' I look this way.
I've traveled a long way, and some of the roads weren't paved.
Will Rogers
FrankNitti is offline
post #2 of 9 Old Jun 18th, 2015, 10:48 am
bmwcoolk1200's Avatar
Re: Coolant Temp
The smart people will likely respond to this but it may be the engine is running leaner ( hotter) due to the lower atmospheric pressure at altitude and simply producing more heat as a result. Normally at altitude, the air temp is lower so this is an interesting phenomena. Possibly lower air density carries less heat away from the radiators also decreasing overall efficiency.
Waiting to be corrected at any moment
Gordon
Sugar Hill, GA
bmwcoolk1200 is online now
post #3 of 9 Old Jun 18th, 2015, 11:06 am
Scouter-50's Avatar
Re: Coolant Temp
I was up in the mountains of Colorado before the Sedalia national pulling a Bunkhouse trailer and mine hit the red zone and I had to let it cool off a bit. I have a feeling the altitude and slow speeds had something to do with it.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #4 of 9 Old Jun 18th, 2015, 11:20 am
deanwoolsey's Avatar
Re: Coolant Temp
Work = heat, so running at high altitudes usually means seeing many more uphill grades and there's much more heat to dissipate. About all you can do is make sure the radiator fins are free of bugs and check the coolant level. Remember too that the LT is a relatively high RPM engine, so downshifting and keeping the RPMs above 4000 can help greatly.
copperstatetour likes this.
deanwoolsey is offline
post #5 of 9 Old Jun 19th, 2015, 6:38 am
GaryEm's Avatar
Re: Coolant Temp
I thought the more speed you have and less RPM was the answer I guess not
Gary
2003 K1200LT
GaryEm is offline
post #6 of 9 Old Jun 19th, 2015, 8:03 am
Re: Coolant Temp
Cooling efficiency de-rates at 3300asl. Does this for all things, not just bikes. Thinner air = less cooling efficiency.
Hoodcounty is offline
post #7 of 9 Old Jun 19th, 2015, 9:36 am
rowie's Avatar
Re: Coolant Temp
Yup - altitude means more work plus thinner air. Net result - motor works harder and therefore hotter.
Mine always runs hotter in the mountains, meaning the fans come on more often. Unless for some reason you're constantly in the red, it sounds normal to me.
BMWMOA member
Current rides:
Prior rides:
Suzuki GS425E (Australia)
Suzuki T250R (Australia)
rowie is offline
post #8 of 9 Old Jun 19th, 2015, 9:47 am
Re: Coolant Temp
Generally more RPM is better, up to a point. You get more friction at high RPM which creates a little more heat, but you also get a lot more coolant flow since the water pump on most engines runs at a speed that is a direct function of engine speed. So you get a little more heat generation, but a lot more coolant flow which is a good trade.
Voyager is online now
post #9 of 9 Old Jun 19th, 2015, 2:23 pm
copperstatetour's Avatar
Re: Coolant Temp
Voyager is right, live in AZ where I do a lot of mountains and high altitude (at this time of the year the only place you can ride is high elevations). I have found repeatedly that unless I am on a plateau that keeping those RPMs around the 4,000 mark will keep my engine running right around (a little above) the middle mark where it normally lives. When I let the engine wallow around in the 3k range the water temp goes up.
I generally prefer higher RPM's in the mountains because I have more power immediately available for when the grade changes to uphill, also already in a lower gear to get some added engine braking when it switches to downhill - win / win in my book.
-Steve
2009 BMW R1200RT
2000 BMW K1200LT (was supposed to be replaced by above, but can't keep above running long enough to replace
2000 BMW R1200C
copperstatetour is offline
Coolant Temp FrankNitti K1200LT 10 Nov 11th, 2012 11:22 am
coolant question 2 Rider999 K1200LT 3 Sep 2nd, 2012 12:35 pm
Torque spec for coolant temp switch smahon K1200LT 9 Mar 5th, 2012 5:43 pm
Coolant Question greg09 K1200LT 8 Aug 24th, 2010 1:02 pm
Coolant temp light and engine shut-down MolenaarD K1200LT 15 Aug 12th, 2006 9:40 am
