ABS light - BMW Luxury Touring Community
post #1 of 8 Old Jun 17th, 2015, 9:36 pm Thread Starter
ABS light
I have an 02 LT, last year I changed the brake pads using aftermarket pads, it seems that's when this started happening. The ABS and warning lights flash, my battery was five years old so I changed it using a scorpion battery. This didn't solve the problem, although the lights initially stopped flashing, it was only temporary. The brake level in the right handlebar is slightly low, I am going to top that off and see if that helps. I have 48K on the bike and am getting ready to do the service, I would like to know if this is a serious issue or something simple I can take care of before I send the bike in. Anyone have this problem? Thanks.
schwabee is offline
post #2 of 8 Old Jun 17th, 2015, 9:48 pm
GaryEm's Avatar
Re: ABS light
The brake level under seat in the two reservoirs is the ones you have to check if they are so much as table spoon down your lights will flash
Gary
2003 K1200LT
GaryEm is offline
post #3 of 8 Old Jun 18th, 2015, 12:26 pm
Re: ABS light
Brake fluid is low. But be sure to check for leaks. Just had to change my brake lines due to this problem.
Notahog is offline
post #4 of 8 Old Jun 18th, 2015, 9:19 pm
Re: ABS light
The rear mounted reservoir is notorious for signaling "low fluid" when just a teaspoon of DOT 4 added will stop it. Two chambers two caps fill both as much as you can. Don't even mess with the front lever reservoir as it will never go down (unless you have a leak). The fluid only goes as far as the ABS unit and no farther.
ID:	82522   Click image for larger version
post #5 of 8 Old Jun 23rd, 2015, 8:53 am Thread Starter
Re: ABS light
Thanks for the advice, what is the easiest way to get to the rear reservoir? I seem to be having a major brain fart.
schwabee is offline
post #6 of 8 Old Jun 23rd, 2015, 9:17 am
johnbaker15's Avatar
Re: ABS light
It's under the passenger seat, on the right as sitting on the bike. Two screws hold the seat, if heated there is also one connector to unplug. HTH
John Baker
2005 BMW K1200LT
1979 Suzuki GS1000E
1978 Honda CB350
1975 Suzuki GT380
johnbaker15 is offline
post #7 of 8 Old Jun 23rd, 2015, 3:20 pm Thread Starter
Re: ABS light
Thanks for the help, I got to the rear reservoir, what a pain in the ars, and added fluid. Fingers crossed, no lights flashing. Just as you guys said, it wasn't even below min, just a bit lower than max. $5 and an hour of my time. Thanks again.
schwabee is offline
post #8 of 8 Old Jun 23rd, 2015, 7:55 pm
Re: ABS light
As your pads wear the level will drop again. Just add more fluid but check your pads just to be safe.
ABS Light Flashing schwabee K1200LT 11 Sep 29th, 2014 10:45 am
ABS Light flashing airborneod K1200LT 5 Mar 18th, 2012 9:35 pm
ABS light on Wheelsca RT Series 13 Mar 12th, 2012 3:59 pm
ABS light flashing.--HELP Please stevie1 K1200LT 1 Jan 13th, 2011 11:23 am
ABS Light Wig Wag nbbusa K1200LT 2 Apr 2nd, 2007 5:01 pm
