Clutch Question - BMW Luxury Touring Community
 5Likes
  • 4 Post By Voyager
  • 1 Post By jzeiler
post #1 of 17 Old Jun 16th, 2015, 5:37 am Thread Starter
deputy5211's Avatar
Clutch Question
Replaced my clutch two years ago, or was it three.
IIRC, as the clutch wears, it will engage sooner, with the clutch lever closer to the hand grip.
Mine seems to be doing the opposite, I have a very small friction zone, and it is close to full outward extension of the lever. It seems that it was engaging with the lever more fully released since the clutch job, but it seems that the engagement point is migrating ever so slowly closer to full outward position of the clutch lever.
Am I making sense? It IS early and only one cup of coffee so far.
Antony (Tripod)
Dallas' Northern Suburbs
and many, many others.
deputy5211 is offline
post #2 of 17 Old Jun 16th, 2015, 6:30 am
Scouter-50's Avatar
Re: Clutch Question
Tony, I don't remember, did you change the slave? Sounds like a hydraulic problem. Leaky hose maybe.
Robert
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #3 of 17 Old Jun 16th, 2015, 7:27 am
Re: Clutch Question
hydraulic clutches are self adjusting, have had several, engagement point should only change if the slave or master has a problem. The fluid will fill the master reservoir as the clutch wears opposite of the brake reservoir which goes lower as the pads wear
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #4 of 17 Old Jun 16th, 2015, 8:34 am
Re: Clutch Question
Hydraulic brakes and clutches are typically self-adjusting. The master cylinder has a port that is uncovered at the end of the release stroke that allows fluid to enter or leave the circuit. What should change is the fluid level in the master cylinder.
With brakes, the level should go down with pad wear as fluid moves from the master cylinder into the increasing volume in the slave cylinders. I have not yet had my LT apart, but I believe the clutch slave is just the opposite. It pushes the pressure plate away from the clutch disk. As the disk gets thinner, the pressure plate moves closer to the slave cylinder causing the volume of the slave to decrease. This displaces fluid back into the master cylinder increasing its fluid level.
I also have a small engagement zone and it is towards the end of travel of the lever. I recall that mine has always been that way, but seems to be worse since oil started weeping from under the engine and, I suspect, contaminating the clutch. Although, after slipping a few times last year while traveling to NL, I can't make it slip this year. Go figure. I planned to tear it down in June after my 5/31 retirement, but now plan to finish the riding season and tear it down this winter, unless the slipping returns with a vengeance. I have no real long trips planned this year and don't fear making a few 800 mile trips with it.
My past wet clutch bikes all had broader engagement travel and began to engage much earlier in the lever travel. I chalk the late/narrow engagement up to the dry clutch design.
post #5 of 17 Old Jun 16th, 2015, 8:54 am Thread Starter
deputy5211's Avatar
Yes, Robert, slave (and hose) replaced.
No leak detected.
Progression of engagement point may be only in my mind.
Glad to hear late engagement not necessarily a problem.
Reservoir is full. When I flush it, no air gap. No slipping.
post #6 of 17 Old Jun 16th, 2015, 6:44 pm
Axle's Avatar
Re: Clutch Question
mines all new, clutch doesn't kick in until the lever is nearly fully out as well, must be normal i guess.
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #7 of 17 Old Jun 16th, 2015, 7:01 pm
Scouter-50's Avatar
Re: Clutch Question
No leak detected.
Tony, is it possible that you moved the dial on the lever? I did that once and thought I had a problem.
Robert
1981 R80GS
1976 R90S
post #8 of 17 Old Jun 16th, 2015, 8:08 pm
Re: Clutch Question
Also bear in mind that the fluid level will RISE in the reservoir as the clutch wears. You don't want it over full.
post #9 of 17 Old Jun 16th, 2015, 8:46 pm
Axle's Avatar
Re: Clutch Question
Robert
I thought that adjustment only brought the lever closer/further away from fingers, I dont think it actually adjusts anything, the push rod doesn't move only the lever ??
ok I just realised how it works Duh!
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #10 of 17 Old Jun 16th, 2015, 9:34 pm Thread Starter
deputy5211's Avatar
Re: Clutch Question
Robert
Possible? Of course. Would it adjust the length of the friction zone, though?
Antony (Tripod)
post #11 of 17 Old Jun 16th, 2015, 9:36 pm Thread Starter
deputy5211's Avatar
Re: Clutch Question
I flush the clutch at least once a year, John, as it is soooo easy with a SpeedBleeder and an empty IV bag.
Antony (Tripod)
post #12 of 17 Old Jun 16th, 2015, 9:36 pm Thread Starter
deputy5211's Avatar
Re: Clutch Question
Linton, what did you just realize?
Antony (Tripod)
post #13 of 17 Old Jun 16th, 2015, 11:20 pm
Axle's Avatar
Re: Clutch Question
there are 3 positions on the dial 1 being the closest, if you have selected say 1 then the lever is 2 clicks closer to the bar, so as you release the clutch lever it appears to engage the clutch earlier when in fact, the clutch engages the same as before say if you were on 3. as I said the lever moves not the push rod.
Regards Linton
2002 K1200LT
My Toys
1976 Datsun 260Z
Axle is offline
post #14 of 17 Old Jun 17th, 2015, 12:00 pm
bmwcoolk1200's Avatar
Re: Clutch Question
I believe that is correct. The dial on the lever adjusts the maximum travel of the slave cylinder when the lever is completely against the grip.
Mine was set at 1 and until I figured this out, I had issues with shifts being more difficult that I thought they should be. So I set it at 2 and that disengaged the plate a little further and actually seems to shift easier now ( for me). I think it was not fully disengaging and still applying some spin force on the tranny making shifts noisy/harder than they should have been.
There is an adjustment screw on the handle that is set with locktite for the actual handle play. I would not think that would need adjustment unless you replaced/rebuilt the master cylinder. I believe there is an adjustment procedure in the Clymer book if needed.
Gordon
Sugar Hill, GA
bmwcoolk1200 is offline
post #15 of 17 Old Oct 22nd, 2015, 9:22 am
dladika's Avatar
Re: Clutch Question
I'm the new guy! Getting use to the decidedly different feel and sounds of the LT. Love the bike. I just purchased an '07 LT with only 12K mile on it. My clutch does engage almost at full release of the leaver and it takes more rpm's to "get her moving" than I would have thought. So different from any other bike I've had. Wondered if it was normal, but master cylinder level is just right and it doesn't slip and from what everyone is saying, it is "normal" for this bike. Thanks. Doug
dladika is offline
post #16 of 17 Old Oct 22nd, 2015, 10:00 am
Re: Clutch Question
The LT is a heavy bike with a relatively small engine with little torque and rotational mass and a way too tall first gear. This makes for challenging and slow launches and the need for higher than desirable RPM which wears out the dry clutch sooner than normal for other bike.
Just the nature of the beast. Don't ever challenge a v-twin cruiser or a gold wing at a stop light. They will eat your lunch.
Wait until you are rolling in first gear or until on a very curvy toad before challenging anyone.
post #17 of 17 Old Oct 22nd, 2015, 9:28 pm
Re: Clutch Question
Recommend working on learning how to release the clutch with no more throttle than necessary to maintain no more than 1,200-1,500 RPM until the clutch is fully engaged. This will preserve the life of the clutch. Once the clutch is fully engaged roll on the throttle and take her to 8,000 RPM and shift into 5th as you will be doing 60 MPH.
If you try to do a high RPM launch like a wet clutch sport bike all you will do is wear out the clutch. Do the slow launch followed by the fast get away. You won't get the hole shot but you will pass them before they shift into third.
Mark65 likes this.
Clutch master cyl. question jbwbhs K1200LT 3 Jun 15th, 2013 5:41 pm
05 r1200gs Clutch fluid question? byke33 GS Series 2 Apr 3rd, 2010 6:29 pm
RT Clutch Adjustment Nebish RT Series 17 Apr 1st, 2009 10:51 am
question on clutch resevior byke33 GS Series 1 Aug 22nd, 2007 12:08 pm
Clutch Repair Question 02lt K1200LT 2 Jun 6th, 2006 12:24 pm
