Fork Seals - BMW Luxury Touring Community
 5Likes
  • 3 Post By Scouter-50
  • 1 Post By jzeiler
  • 1 Post By Jimmymac
post #1 of 10 Old Jun 15th, 2015, 6:02 pm Thread Starter
Fork Seals
Just change fork oil seals clips and dust boots. Went for a ride and have a bit of oil leaking at the top of the fork. Any advice would be appreciated.
Cheers
Jimmymac is offline
post #2 of 10 Old Jun 15th, 2015, 6:59 pm
Re: Fork Seals
Cheers
There are bushings inside the slider that keeps the stanchion centered in the seal.
Is it possible you put too much oil in the slider when putting back together
I failed to replace the bushings when rebuilding my other K forks and they were leaking after a couple hundred miles.
Gary
2018 R1200RT
Past rides
2012 K1600GTL
2000 K1200LT
1992 K1100LT
1985 K100RT
1965 R60/2
1960 AJS 500 single
gary45 is offline
post #3 of 10 Old Jun 15th, 2015, 7:07 pm Thread Starter
Re: Fork Seals
Leaving on a trip on Friday. Plan to monitor the situation. Do you know the down side of this situation on a 3000 mile trip?
Jimmymac is offline
post #4 of 10 Old Jun 15th, 2015, 7:14 pm
Scouter-50's Avatar
Re: Fork Seals
If it continues tie a rag around it and keep on truckin'. you'll be fine till you get back.
Robert
mtrevelino, Patric and saddleman like this.
2000 K1200LT "Latifah"
1994 R1100RSL (wife's)
1981 R80GS
1976 R90S
2011 Bunkhouse Queen
Scouter-50 is offline
post #5 of 10 Old Jun 15th, 2015, 7:25 pm Thread Starter
Re: Fork Seals
Jim
Jimmymac is offline
post #6 of 10 Old Jun 15th, 2015, 8:39 pm
Re: Fork Seals
Just that your forks will be dirty. I don't think you will pump out all the oil.
Patric likes this.
post #7 of 10 Old Jun 15th, 2015, 9:26 pm
Re: Fork Seals
Little downside if you wipe off the dirt and oil frequently. The biggest issue is that oil attracts grit and forms a fairly effective grinding compound. That is rough on the seals and, in the extreme, can scratch the fork tubes causing oil to weep forever even with new seals.
I would try to wipe things clean at the end of each day to minimize the dirt build-up.
post #8 of 10 Old Jun 17th, 2015, 1:12 pm Thread Starter
Re: Fork Seals
Will do. Is there a way to top up fork oil without removing the slider?
Jimmymac is offline
post #9 of 10 Old Jun 17th, 2015, 9:29 pm
Re: Fork Seals
Well not an easy one. Way up at the very top of the fixed tube is a breather hole and I suppose you could add oil there. But I really don't think you will lose much more than an oz or two as a nuisance, it will not affect the remainder of the oil. In other words you can't run it dry unless you lay down the bike.
post #10 of 10 Old Jun 30th, 2015, 11:46 am Thread Starter
Re: Fork Seals
Got back from my trip. No oil leaking throughout. Suspect I over filled the fork and with compression a few drops of oil was leaking out the air hole and running down onto the dust boot. In time the leak disappeared. Feeling better about the situation now.
Patric likes this.
Jimmymac is offline
leaking fork seals jwacree Bike Talk 4 May 26th, 2014 1:58 pm
Leaky Fork Seal(s)? Easy fix. hallzee K1200LT 7 Sep 18th, 2012 7:37 am
Fork seals 2002redrider K1200LT 2 Jun 9th, 2010 11:43 am
Changing Fork Seals tonyn1 Shocks and Suspension 0 Apr 25th, 2009 9:04 am
One thing leads to another. Fork Seals JPSpen K1200LT 10 Apr 30th, 2006 6:36 pm
